Axles |
Topic: Axles Posted: 03 May 2020 at 3:12pm |
I think a single axle is OK, there are a lot of single axle trailers about the same weight as the 195.
The axle is mounted farther outboard on the wider frame of the 195/6 which is helpful. Also, you typically end up with more hitch weight than you're thinking you do, that 362 lb figure is unrealistic. More hitch weight means less weight on the axle for the same max trailer weight. A typical hitch weight on a well loaded 195 is probably going to be around 600 lbs, which puts the axle load at around 4000 for a trailer that is loaded around 150 lbs below max. That would give you a 13% hitch weight which is a good place to be.
I'd definitely look into upgrading tires though....and no way I'd tow that thing with my Highlander |
Olddawgsrule
Senior Member Joined: 20 Sep 2017 Location: New Hampshire Online Status: Offline Posts: 1014 |
Posted: 03 May 2020 at 3:11pm |
Not without beefing up the frame first! The frame and axle are a very close match.
crazycoyote
Groupie Joined: 22 Jan 2017 Location: Arizona Online Status: Offline Posts: 49 |
Posted: 03 May 2020 at 10:32am |
I think it's time for a dual axle setup on the Rpods, to close of weight on a single axle trailer.
Posted: 02 May 2020 at 7:32am |
Not sure where you got your numbers. The FR website has the 195 at a hitch weight of 362, an unloaded vehicle weight of 3587, and a cargo carrying capacity of 1175. 3587+1175= 4762 which is the GVW. Subtract the hitch weight and you get 4767-362=4400 for the axle. https://forestriverinc.com/rvs/travel-trailers/r-pod/RP-195/4588
Actually loading that trailer like that would be a terrible idea though as that would put the hitch weight at only 7.6% of trailer total weight. Its almost certainly going to sway big time. You want the hitch weight to be at least 10% of the trailer weight, preferably more like 12-13%. The DOT requires the mfgrs to state the GVW as the total of the lowest listed hitch weight and the axle capacity. The mfgrs are motivated to publish a low hitch weight because that is commonly the limiting factor on the tow vehicles. So you end up with this weird loading scenario. So actually weigh what you have ready to roll, you'll probably be surprised by how much higher your tongue weight really is. And then adjust your load fore or aft accordingly if needed to keep everything well within your trailer and TV limits. And if you're going to get a 195 to be safe I'd recommend planning on needing a TV with a hitch weight rating of at least 600-700 lbs. |
crazycoyote
Posted: 01 May 2020 at 9:35pm |
SO, take the model 195, the hitch weight is 340 and the GVWR is4790, and with a 4400 lbs axle, my figures overload the axle, and I think the 196 is still more weight. Does that seem right?
Posted: 01 May 2020 at 6:10am |
4400 lbs. Here's how you can tell. Take the UVW and add the CCC to get max trailer weight. Then, subtract the minimum listed tongue weight (in the case of rpods there is only one listed tongue weight so use that). DOT requires that the trailer mfs do it that way.
Also count lug bolts. The 3500 lb rated axles on the smaller rpods have 5, the higher rated axles should have 6. Otherwise they are probably the same axle, just rated differently.
crazycoyote
Posted: 01 May 2020 at 12:15am |
Does anyone know what size axles FR puts on there 95 or 96 Rpod models?
