Furnace Rumble |
Post Reply | Page <12 |
Kup-Pod
Senior Member Joined: 08 Jun 2017 Location: Guelph, Ontario Online Status: Offline Posts: 153 |
Topic: Furnace Rumble Posted: 13 May 2020 at 8:36pm |
no problem
If you do figure it out, don't forget to post the solution - I have used the search tool plenty of times to figure out what was wrong. Everytime I fix something on our Pod, my wife and kids sarcastically ask me, "did you learn that from the RPod forum?"
2017 RP-178
2021 F150 5.0l "Lead me on a level path" |
Posted: 13 May 2020 at 8:56pm |
I think you might be better off having a qualified technician check this out. Depending on the age of your RPod, it may be something covered under warranty. Even so, it is better to be safe than sorry. See page 2 of this document: It it turns out that it is just a burner adjustment issue, that is not covered under the warranty. If you try to fix it yourself while any warranty is remaining, you will void your warranty. Edit: I re-read the original post. While the 2 year warranty has expired, the additional 3 year heat exchanger warranty is still in effect.
Rpoder76
Newbie Joined: 12 May 2020 Online Status: Offline Posts: 9 |
Posted: 13 May 2020 at 8:58pm |
I have had this inspected several times by qualified technicians. That's why I'm posting it here, because technicians can't figure it out, and maybe someone else has had the same problem. I'll register the fan behavior being different with burner lit as a possible theory. I'd like to hear though, if anyone else has had this problem.
Posted: 13 May 2020 at 9:04pm |
I have not noticed this behaviior. Why don't you contact Airxcel and describe the issue? They might be better able to give you an answer. I just had a thought. Have you checked the air inlet side to see if there are any obstructions (such as a wasp nest) in there? I have screens over all the vents in our RPod because I did have a problem with a mud-dauber nest in the refrigerator burner when we first bought our RPod.
Posted: 14 May 2020 at 6:23am |
Hmm. Interesting problem, seems from the description like it might be a fuel delivery issue but you've already replaced the regulator. Maybe a kinked line or water in the line?
One thing you could do to be certain that the problem is in the furnace itself and not the propane delivery system is to connect a regulated propane cylinder directly to the furnace itself. If the problem goes away then focus on the trailer propane system, if its still there then maybe the furnace gas valve or burner.
Rpoder76
Posted: 14 May 2020 at 7:53am |
Thanks, yes this is an interesting thought. Someone once mentioned "grease" in the line, though I don't know how that would get there.
Posted: 14 May 2020 at 1:34pm |
Propane is a petroleum product. Over time, oils will accumulate in the line as the propane reacts with the lining of the hose. I have gotten a significant amount of liquid out of the lines when I was troubleshooting why my refrigerator was not cooling adequately. It could very well be why your furnace is misbehaving. Take the line loose from the regulator. Take it loose from the furnace. Using an air hose at the furnace end, blow out the line. Have something under the end of the hose from the regulator. I think you will be surprised at the amount of liquid in the line if you have never done this before.
