BMJ
Topic: AC error code Posted: 15 Jun 2020 at 10:01am |
Have a new RPod 195...AC was working, until yesterday... fan motor runs but compressor doesn’t engage. I’m thinking it’s the capacitor or relay... hoping it’s not a bad unit! Yet still under warranty. Any similar issue with the Dometic unit?
Thanks
Pod People
Posted: 19 May 2020 at 5:42pm |
I'm sure that any invoice from a fellow Pod owner would be worth substantially more and actually cost substantially less than a local "dealer" Thanks again to the active forum Vann
Vann & Laura 2015 RPod 179
Posted: 19 May 2020 at 2:41pm |
No service charge from me, I'm sure you'll return the service one day, I'm only a couple hours up the road from you!
podwerkz
Posted: 19 May 2020 at 2:22pm |
Right before you rebooted it I logged in by remote and fixed the problem.
I will bill you soon.
Pod People
Posted: 19 May 2020 at 12:33pm |
Offgrid, You were exactly right-I unplugged everything and killed the battery switch-turned it back on and it worked perfectly. THANK YOU!!! Once again, the forum saved the day with expert input from another smart owner Vann
Posted: 19 May 2020 at 12:15pm |
Its some kind of sensor error I think. Try disconnecting all power (including disconnecting the battery + terminal) to see if that resets it.
Pod People
Posted: 19 May 2020 at 11:25am |
I just dewinterized and am getting the Pod ready to go whenever the camping opens. I am hooked up to shore power on a dedicated 30 amp circuit. When I turned on the Dometic AC unit, the thermostat showed “E4”. I assume this is an error code as nothing would come on(no heat, AC or fan operation) Can anyone tell me about the “E4” error and what can I do to resolve this. Thank you Vann
