Floor Collapse -wet floor |
Post Reply | Page <12 |
Cocared
Newbie Joined: 30 May 2020 Location: Houston Online Status: Offline Posts: 12 |
Topic: Floor Collapse -wet floor Posted: 29 Jun 2020 at 5:00pm |
Hi, I was wondering if I could get your opinion? We just bought a 15 178 from a private owner and just discovered there must have been a leak. We can not locate the leak yet but we have found the whole underbelly wet, some areas super soft and wet. In your opinion, is this salvageable? Thank you in advance! We started removing the black cover to let the wood dry out.
2015 Rpod 178
Junkinpod
Newbie Joined: 04 Jun 2019 Location: ON Online Status: Offline Posts: 18 |
Post Options Quote Reply Posted: 29 Jun 2020 at 10:06pm |
I removed all of the flooring first. I have not opened up the underbelly yet, but I assume that this is a step that I will have to do. My floor was always soft in front of the sink/bathroom - but had no idea how bad the floor was until I saw that the wall and floor had dropped. I believe the water came in around the slide on mine - but will post more as I start to work on it. Sorry you have had this experience - how frustrating.
Belinda
Post Options Quote Reply Posted: 30 Jun 2020 at 4:45am |
The floor is a composite of foam insulation with plywood on top, then the finish floor. The whole trailer is built on top of that. The structural strength is in the plywood, so if that becomes saturated and delaminates then you have a problem. If its still intact then you can probably just dry things out and be fine. If its delaminated and soft in some areas but not sagging then you can probably repair it by adding another layer of plywood over top, cut out to fit around the walls and cabinets, and glue and screw it down.
The first step either way is to find the leak, fix that, and get the trailer dried out. Open up the bottom so the moisture can get out of the foam, and remove the finish floor in any areas where the plywood is wet and get some warm dry air blowing on it.
Olddawgsrule
Post Options Quote Reply Posted: 30 Jun 2020 at 7:25am |
I'd get that outside wall jacked up and some jack stands under the wall. I would span the length in question with another support (I'd use some sq stock steel I have around) and at least a couple jacks (I would use my 3 bottle jacks) once up support with the jack stands. I won't do much messing around till that is supported, never know what else can occur. A 2016 video shows a 2" sq stock aluminum floor frame. It will be interesting to learn if it's on yours and if it goes to the outside wall. My belief is it's a composite 'on' frame and explains the dropping away. |
Junkinpod
Post Options Quote Reply Posted: 10 Jul 2020 at 9:28am |
See new post - Broken welds on floor joist to see what I've discovered after removing the flooring.
Belinda
Teck2
Newbie Joined: 01 Jul 2018 Location: NY Online Status: Offline Posts: 6 |
Post Options Quote Reply Posted: 21 Aug 2022 at 1:59pm |
We are having the same problem with our R-pod 182g right now. Were you able to fix the floor?
AlistairF
Newbie Joined: 30 Aug 2023 Online Status: Offline Posts: 1 |
Post Options Quote Reply Posted: 12 Sep 2023 at 11:53am |
Anyone ever do a step-by-step guide/video to how to replace their R-Pod floor?
Post Options Quote Reply Posted: 12 Sep 2023 at 4:06pm |
Seems to me that a full floor replacement's cost in labor and material would exceed the fair market value of almost every rPod in need of such a drastic repair.
gpokluda
Senior Member Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 275 |
Post Options Quote Reply Posted: 12 Sep 2023 at 5:56pm |
+1 I would speak with your insurance company and see what options there are.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Triumph T120 |
