Fridge not cooling |
Post Reply | Page <1234 5> |
marwayne
Topic: Fridge not cooling Posted: 03 Jul 2020 at 11:00am |
Posted: 03 Jul 2020 at 11:15am |
That is most impressive marwayne, like everything else you do on your R-Pod! My temp has not changed inside the fridge although outside it is up to 94. I have the fridge side facing north so the sun only hits it until 10:30 so now it will reside in shade the rest of the day.
Posted: 03 Jul 2020 at 1:13pm |
I can't find a chart to show the relationship between ambient temperature and refrigerator temperatures for absorption refrigerators. At this point, I would blow out the LP line and see if it makes a difference. On our recent trip to the coast, we were maintaining temps in the 30's in ambient temperatures in the high 80's while set to 4 bars.
Posted: 03 Jul 2020 at 5:15pm |
Haven't seen such a chart either, probably because an RV absorption fridge is a a pretty complex device thermodynamically. Check out this slide presentation:
If you go to around slides 17-20 you can see that the COP of an absorption fridge is related to three temps (To-condenser/absorber), Te -evaporator, and Tg -generator). I didn't run the numbers, but since To (essentially the ambient temp) is showing up twice, in the denominator in one case and subtracted in the numerator in another) COP is going to fall off quickly with higher ambient temps. And if COP drops cooling capacity drops along with it. To run the numbers you would need Tg, essentially the hot air from the propane flame or electric element. I found one reference for that which is around 350F. Note that you would need to do this calc in degrees above absolute zero (Rankine or Kelvin degrees), not in F or C. The reference with the Tg of 350 was this, which is an interesting discussion of what causes damage to RV fridges and how to prevent it. |
marwayne
Posted: 03 Jul 2020 at 5:27pm |
Jato, Cleaned up the fridge outside and turned it on, went from 23* C to 6* C in about 4 hours on LP
Posted: 03 Jul 2020 at 6:50pm |
Marwayne, that sounds like our weather here in NV last week. 23℃ in the afternoon and down to near 0℃ at dawn.
marwayne
Posted: 03 Jul 2020 at 7:02pm |
It's been cool and wet.
Posted: 03 Jul 2020 at 7:53pm |
Last time I was in Edmonton, a Feb. about 10 or so years ago, it never made it to 0℉. It was especially entertaining watching cars trying to go up a moderately steep hill and slide back down to the bottom to try once more. I think I'd rather winter in Vancouver or Victoria.
marwayne
Posted: 03 Jul 2020 at 8:12pm |
If you can afford to live there, and I couldn't stand the grey rainy weather in the winter
Posted: 04 Jul 2020 at 5:54am |
I didn't think you needed fridges in Canada?
