Water pressure |
Post Reply | Page 12> |
Cadeeli
Newbie Joined: 05 Jul 2020 Online Status: Offline Posts: 3 |
Topic: Water pressure Posted: 06 Jul 2020 at 12:23pm |
Is it normal to have extremely low water pressure when running water from water tank?
We just bought our first camper - rpod 182g. We recently camped at a koa with hook ups and I took a great shower. We usually do not camp with hook ups. Every shower since has been trickling down the shower wall. Perhaps the pump isn’t as strong as I was hoping. |
Posted: 06 Jul 2020 at 12:59pm |
Could you please let us know if this situation repeats itself when you are using water from the FW tank. Also how is the pressure when you use the H and C at the sink and at the outside shower if you have one? There is a good chance that the screen in your shower head is plugged with debris. Take it apart and see if that may be the case.
Cadeeli
Posted: 06 Jul 2020 at 1:31pm |
Thanks for your help! It is consistent when using water from FW tank. Pressure is pretty good at sink and excellent at outdoor sink. I will check the shower head, however, the previous owners never used the shower 🤔
Is it normal to have better pressure overall when hooked up to water? We do have a pressure regulator if that means anything. |
Posted: 06 Jul 2020 at 1:51pm |
it might be higher pressure when connected to city water but it should be fine on the pump too. You don't have the little shutoff valve on the shower head closed by any chance do you?
Posted: 06 Jul 2020 at 2:49pm |
Sounds like the screen at the shower may be clogged. This is quite common for the faucet at the kitchen sink; maybe not quite as often for the shower.
Pod_Geek
Senior Member Joined: 04 Dec 2019 Location: Colorado Online Status: Offline Posts: 260 |
Posted: 06 Jul 2020 at 3:20pm |
My read is that when hooked up to city water the shower pressure is fine, but not so much when using the FW tank/pump. Cadeeli, did I get that right?
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L |
Cadeeli
Posted: 07 Jul 2020 at 3:06pm |
Correct.
RoverPod
Senior Member Joined: 07 Mar 2020 Location: Virginia Online Status: Offline Posts: 118 |
Posted: 07 Jul 2020 at 6:37pm |
Is it possible that the screen/filter in the pump itself is clogged?
Posted: 07 Jul 2020 at 6:43pm |
I think it would always have a pressure issue. Not be good in city water and bad on the water pump. The water pump itself could be the issue.
Posted: 07 Jul 2020 at 7:36pm |
On ours, between the pressure restrictor and the water filter on the city water connection, we get better water pressure in the shower with the water pump.
