  New Posts New Posts RSS Feed: tires
Topic Closedtires
yogamoment View Drop Down
Direct Link To This Post Topic: tires
    Posted: 12 Jul 2020 at 1:47pm
Heidi Schultz
Direct Link To This Post Posted: 12 Jul 2020 at 1:48pm
There has been a concern with the tires on R-Pods that they have a lot of blow outs.
Is there any concerns with the 225/75 R ones on the 2020 171 ?
We just bought a new R-pod and feel like I should replace them?
Heidi
Heidi Schultz
Direct Link To This Post Posted: 12 Jul 2020 at 2:26pm
Need a little more information. What is the full label on the tires? Are they ST tires? Wheel size? Load range? Speed range if listed? Manufacturer?
mjlrpod View Drop Down
Direct Link To This Post Posted: 12 Jul 2020 at 3:13pm
I personally do NOT need anymore information. It's a fairly accepted fact that R-pods (and many others) come with crappy inferior tires, and I would recommend changing them out immediately. I have gone from the dealership to the tire shop for new tires on both of my new pods. When you have only one axle, what you put on there really matters. It'll cost you about 200 dollars to put a good set of carlisle radial tires on. Just one blow out of the inferior tires will cost over 500 dollars with the new fender, towing, new tires, new rim ETC...
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 12 Jul 2020 at 4:11pm
I would have said the same thing last year but we recently had a post from one new owner who had OEM tires which were 15 inch LRD's with a 2500 lb rating IIRC. So, hopefully FR has addressed this issue now.
Pod_Geek View Drop Down
Direct Link To This Post Posted: 13 Jul 2020 at 1:12pm
Our 2020.5 195 came with 15-inch ST 235/75s LRD rated at 2910 lbs (single axle).  Speed rating 75 MPH.
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
Direct Link To This Post Posted: 13 Jul 2020 at 2:47pm
Pod_Geek, your tires sound good, buy you have a heavier trailer with a 4400 lb rated axle.  So we still need to know what the OP's tires are rated for.
Direct Link To This Post Posted: 13 Jul 2020 at 4:50pm
Of course.  I was just adding a data point that agrees with your recollection to make you seem even wiser.
2018 RAM 2500 6.4L
Direct Link To This Post Posted: 14 Jul 2020 at 6:40am
LOL
Okie1941 View Drop Down
Direct Link To This Post Posted: 24 Jul 2020 at 10:25am
Originally posted by yogamoment
The asphalt highway in the sun is over 140 today. Temperature and speed causes tires to blow. Get the best tires you can and add metal stems and a Tire Pressure Monitoring System (TPMS). I will carry a DeWalt inflator and check tires every morning. I also watch pressure on TPMS and let air out during the day as it improves , ride, handling and safety. It's a science and includes measuring the weight on each wheel and adjusting pressure accordingly.
