  New Posts New Posts RSS Feed: RP 189 tv booster
Topic ClosedRP 189 tv booster
Buffalohunter View Drop Down
Direct Link To This Post Topic: RP 189 tv booster
    Posted: 13 Jul 2020 at 6:56pm
i have a 2020 rp189...with a tv antenna booster on the roof. All the interior cables disappear in to the instrument box just above the TV set. There are the switches for the lights, awning, radio, speakers and the solar control panel. Is your 189 of the same configuration? If so are you ok with the tv booster, mounted on the roof, constantly sucking power from wherever or have you found a way to turn it off? Enclosed instrument boxes drive me crazy cause all I can do is sweep up the styrofoam snow that falls out of the cable hole leading into this black box. Thanks thought I would check with other 189 poders.
R-pod-2020 189
2013 Toyota Tacoma
