2TrvlMore
Topic: New RV'r -got an RPod 190 Posted: 17 Jul 2020 at 12:28pm |
Oh wow, I handn't even thought of a surge protector! Thanks MJLRPOD! We will look into that right away! I notice there are 2 keys to open the door, and yeah, that sounds great to have keyless. Tires are the 1st thing we replaced. :) Thanks for the excellent tips!
mjlrpod
Posted: 17 Jul 2020 at 1:27pm |
The surge protector is not cheap, about 250.00 bucks. Don't waste time and money on analyzers, they only tell you if its good this very second. An EMS will monitor power before allowing it into your camper, and then keep monitoring it 24-7. I hate keys, I have had keyless entry for at least 10 - 15 years at home, and 5 years on my camper. It s*&ks carrying keys in your bathing suit.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
2TrvlMore
Posted: 17 Jul 2020 at 3:27pm |
Is there a particular surge protector you like or can recommend?
Posted: 17 Jul 2020 at 3:36pm |
You DO want the analyser function as that tells you whether you have an open ground, neutral, or line and neutral reversed before you connect. You also want the surge protector function to handle transient voltage surges in the campground power lines. So, get a device that has BOTH functions.
GlueGuy
Posted: 17 Jul 2020 at 5:04pm |
I think a non-contact voltage detector would suffice to be certain that there isn't some major wiring problem in the pedestal. That and a DVM and probably a AC test plug. I carry all three, and it only takes a couple of minutes to check that your power is good.
As for keys, we got replacement locks for the storage access door and the outside shower door. That way, one key opens them all.
I think the permanently mounted surge protector is a great idea.
mjlrpod
Posted: 18 Jul 2020 at 9:15am |
I use the Progressive EMS HW30C, (hard wired) unit in mine. As IMO incorrectly stated above, you DON"T need the analyzer, because the EMS will analyze the power BEFORE it allows it to enter the camper. Once you plug in, it takes about 10 seconds before you hear the power kick in. If there is any problems with the pedestal, open ground, reverse polarity, ETC. It will block the power and display and error code associated with the problem. Buying the analyzer would be repetitive and wasteful. I recommend "hardwired" because you only install it once, and it's always ready to go. No reason to hang a 250 dollar lure outside, or forget to take it with you. Remember, an analyzer only tells you if the power is good "before" you plug in, I want to know it's good " while " i'm plugged in.
2017.5 Rp-172
2020 R-pod 195
I'll be rpodding
Posted: 18 Jul 2020 at 9:59am |
Let's get our definitions straight:
While the surge protector only protects your appliances from sudden electric surges and high/low voltage spikes, an EMS offers you full protection against all power related issues including current surges, low and high voltage spikes, open ground, reserved polarity, high neutral, incorrectly wired power outlets, and more.
So, let's see if we can reach agreement that a surge protector alone is not adequate and what we want is an EMS, a device that provides both for a circuit analysis and surge protection. Or, you can get individual devices as GlueGuy suggests and check the power at the pedestal that way, plus a surge protector for transient surges.
mjlrpod
Posted: 18 Jul 2020 at 10:50am |
Yes, I fully agree with this. This is partly my fault for sure, because I only consider an EMS, and when I say surge protector, I guess that's misleading. I would never recommend an actual surge protector, because it's more or less a false sense of security. Hence forth, I will be sure to say "EMS" and not simply a surge protector.
2017.5 Rp-172
2020 R-pod 195
I'll be rpodding
Posted: 18 Jul 2020 at 11:14am |
Yes, I fully agree with this. This is partly my fault for sure, because I only consider an EMS, and when I say surge protector, I guess that's misleading. I would never recommend an actual surge protector, because it's more or less a false sense of security. Hence forth, I will be sure to say "EMS" and not simply a surge protector. |
+1
2TrvlMore
Posted: 20 Jul 2020 at 12:25am |
Wow, we are learning A LOT from you guys! Thank you so much! I have been looking into the EMS and I see what you mean when you say it would be better than a surge protector. We had no idea they had such a device out there. We will be installing on before we leave on our next trip. THANK YOU so much for the very invaluable advise! We really appreciate the time you all took to help us understand why this is important. We are still feeling a little overwhelmed, but have been going through all the information that came with the RPod and are getting more familiar with everything. Can't wait to feel confident going on a trip someday soon. I feel like we should have a banner on the RPOD that says "Newbie or Rookie", like they do with "Student Driver's".
