Returning to R-Pod |
Post Reply | Page 123> |
Topic: Returning to R-Pod Posted: 06 Dec 2010 at 10:22pm |
Another good guess. Next time I talk to FR, I'll ask.
Folornhope
Groupie Joined: 22 Nov 2010 Location: Texas Online Status: Offline Posts: 51 |
Posted: 06 Dec 2010 at 11:22am |
A fast guess on the R Pod name...Recreational Pod <hope I spelled that right>.
Posted: 04 Dec 2010 at 8:10pm |
You got that right! The stuff that runs in the slinky ALWAYS runs downhill. Until it hits a fan. |
tdrace
Senior Member Joined: 18 Apr 2010 Location: Florida Online Status: Offline Posts: 133 |
Posted: 03 Dec 2010 at 7:13pm |
I travel alone as well. I have the R-dome and love it. I put it up by myself with no problems. I put the tv outside and watch movies some times. It really expands the trailer. Happy Podding!
tdrace's
2018 180 2010 FORD F150 V-8 equalizer e-2 hitch Sisters on the Fly #1569 |
cane2
Groupie Joined: 06 Dec 2009 Online Status: Offline Posts: 92 |
Posted: 03 Dec 2010 at 6:56pm |
We have a 2010 177 and love it. I cannot tell you about risers or dome as we did not get either. I know there many of you gals out there podding along and doing a terrific job of it, my hat is off to you, i am handicapped and my wife does a lot of the muscle work and yes helps dump. You will find that some dump tubes to be higher than your pod dump i think risers would help here. We got a macerator it pumps the ground up tank fluids up hill. I bought it after we had a dump tube that was 10 inches higher than the popds and that stuff does not run up hill and you do not have to have the slinky
Guests
Guest Group |
Posted: 03 Dec 2010 at 4:08pm |
Brewsterivy
Newbie Joined: 22 Aug 2010 Online Status: Offline Posts: 13 |
Posted: 03 Dec 2010 at 3:44pm |
Thank you - those answers are what I need to know what I am talking about!! I do have a dumb basic question about the riser: does it lift the trailer up a few inches...without lifting the wheels? If I do order it from the company for about $80, who would I get to install it - a local car mechanic or maybe a U-haul dealer? Remember, I am the widowed grandmother who is best at baking cookies!!!
I can hitch, pull and unhitch but anything more than that is probably beyond my capabilities.
Yes, the extra window is on the slideout over the sink/stove. I really like the openness but I never thought about needing wall space. I will have to work on that.
Again, thanks for the info.
Posted: 03 Dec 2010 at 3:20pm |
I agree with David about going with a class 3 and a Prodigy brake controller. The C channel along the bottom edge is there to attach the extra screen provided to keep the bugs out. Mine has never been out of the bag, but I could see needing it in mosquito country. I don't know if they give you enough extra length on that screen to account for the risers so someone else will need to answer that. I think if you order the risers from the factory its only an extra $100 - assuming you aren't buying one that is already on a dealer's lot. You can order the risers directly from the factory for about $80 and install them yourself. Don't order them through a dealer because they mark them up a lot.
Instead of a sway bar I recommend the Equalizer or Equalizer E2, which gives you weight distribution and sway control. The difference in ride quality with vs. w/o a WDH is night and day. I wish I got it years ago for my popup. The E2 has less sway control than the original, but it is also cheaper. If you don't have much of a sway issue with no sway control (I towed for a year w/o any sway control) then the E2 will be fine. Mine was about $450 online.
I think the "r" is just a play on words. ouR-pod
mountain mist
Senior Member Joined: 25 May 2010 Location: Gatlinburg Tenn Online Status: Offline Posts: 426 |
Posted: 03 Dec 2010 at 8:57am |
I wonder if the new Pod is online yet. I would like to eye the new graphics.
The 6th window, is it over your slideout. I had not realized there was a place for another window unless at the kitchen and I need the wall space. 5 windows seems enough. If they had put a window in the front end I would not have been able to put up my beautiful mural.
On the r- dome or a seperate awning. I did not jump in (as I usually do) and waited a season to see what I could handle alone. This rig is for me. Unless I carry a ladder( and do I want to do that) I was not able to even string lights along that groove on the outside. I just ended up stringing them up inside I have an awing in mind ( recommended on this forum) and have seen pictures of it here. If it is still available, I MIGHT go for it. But again, how do I try something out that might get hung up along the groove. I have heard that silicone spray helps, but then I have heard that something there is a screw longer than it should be (and there does not seem to attention to that kind of detail when put together)and it has to changed. My challange was learning to hook up, unhook, pull Anything for the first time and doing pretty well, BUT reworking the Pod, challanged is a good word. I guess when Spring comes I could get a ladder out and go along the grove, maybe pull a cord through it to see if there are any hangups. Might be worth having IF I am going to stay in a place more than a few days. If I am taking a days break, I would not bother.
Hope you enjoy that Pod, I know you will.
I have men out raking up the leaves ( I live up agains't the National Park and my yard is downwind from the falling leaves. Anyhow, they were out going around the Pod and looking underneath. It sure is an eye catching thing.
'11 Forest River r.pod 171
'10 Ford Edge ESCAPE POD Trudi and Austin mini-schnauzers change here, Trudi has gone, Austin now has a small black schnauzer buddy, Bentley |
Guests
Guest Group |
Posted: 03 Dec 2010 at 7:32am |
I'll take a shot a couple of your items.
Personally, I would go with a class3 hitch, as they don't cost much more at all and that gives you plenty of safety margin/overcapacity. Electric brakes - I prefer a proportional controller, like the "Prodigy" brand. It costs a few dollars more, but makes for much smoother braking. I did not have axle risers on my Pod and had no major issues. At one KOA, the sewer pipe was actually higher than the outlet on the Pod but, for typical dumping, it was fine. Many like the risers and I can see them being nice to have - if not too pricey. I did not use the Dome, as I too travel alone. I thought if I ever did, in order to avoid carrying a ladder, I would put a grommet in the "leading edge" of the area that feeds into the channel on the Pod and fashion a "hook on a pole" to help pull it thru to the channel.
I have installed hitches and brake controllers before and it is doable. However, the "pros" will get it done quickly and it will probably cost you an extra $200 or so - vs. buying the stuff and doing it youself.
I hope this helps and good luck on your purchase!
