220 lbs on Roof of rPOD 176 ?? |
rPodCamping
Newbie Joined: 28 Mar 2020 Location: Michigan Online Status: Offline Posts: 21 |
Topic: 220 lbs on Roof of rPOD 176 ?? Posted: 25 Aug 2020 at 4:21pm |
So...........I was looking at the roof of my 2020 rPod 176 today and saw that a bird has built a nest inside the housing of the Dometic air conditioning unit. I'm fairly certain I'll have to get on top of the roof to remove the exterior housing to remove all the sticks and nest-building-materials compacted inside. I don't think I can do this working off a ladder.
I am concerned about putting my 220 lbs of bulk on the roof. Will it hold my weight? Will I break all sorts of weather seals doing so? Any and all suggestions are appreciated. |
Posted: 25 Aug 2020 at 6:04pm |
I weigh about 230 and I've been up there a few times with no problems. Regardless of your weight I suggest laying an appropriately sized sheet of plywood on the roof so you don't have any point loads that can dimple the roof. Stay on hands and knees and stay on the flat center section. Set the leveling jacks first and be sure you have a stable ladder. Its always harder to get back off than to get on...
Posted: 25 Aug 2020 at 6:08pm |
I replied on another forum. Say the same here - I'm on my roof all the time. To do cleaning and waxing, maintenance it's just easier. If your worried about your weight, use a piece of plywood cut to go rail to rail, to spread weight over an area. The roof is pretty substantial.
Posted: 26 Aug 2020 at 8:56am |
+1 I've been on the roof of our 179 many times. If you view the RPod factory video, you will see workers up on the roof. The curved sections at the front and back are not as strong, but as long as you are on the flat portion of the roof, you will be fine.
rPodCamping
Posted: 27 Aug 2020 at 8:14pm |
Thank you to everyone for your replies.
Dirt Sifter
Senior Member Joined: 30 Dec 2018 Location: Right side OR Online Status: Offline Posts: 170 |
Posted: 31 Aug 2020 at 10:47pm |
When I contacted FR and asked about my 250 #'s on the roof, they said they recommend against anyone being on the roof of the Rpods. Suppose I should not apply for a factory job
Greg n Deb 2020 195 HRE
'07 Tundra 5.7L., '17 Tacoma 3.5L. Both with tow packages 1 Puggle, 1 Chihuahua support staff |
Posted: 01 Sep 2020 at 6:48am |
Well thats interesting since at 4:20 ln this construction video there are two guys on a roof. They're kinda skinny looking tho
Senior Member Joined: 06 Sep 2016 Location: Quaker Hill, CT Online Status: Online Posts: 2587 |
Posted: 01 Sep 2020 at 7:32am |
FR will likely recommend against anyone going on the roof if directly asked. They don't want to be blamed for a fall. On the other hand, if you look at their recommended maintenance, they suggest inspecting and maintaining the roof seals and penetrations. Clearly that can't be done without getting up onto the roof. If you asked them, they'd tell you to take it to an authorized dealer for work.
I climbed up onto the roof of our Pod many times to no ill affect. It's plenty strong to hold a 220 lb. person. If you are concerned, add a piece of plywood to spread the weight a bit and try not to put all your weight in one spot by sitting down & scooting to your points of work. Just be really careful with the plywood so it doesn't slide off the roof and don't go up there unless you are agile enough to do it safely.
Posted: 01 Sep 2020 at 4:13pm |
+1 to Lost Again and others.
Posted: 01 Sep 2020 at 4:46pm |
I think I would only add one thing. Put some sort of rubber non-skid under the plywood if you use that. The last thing you want to do is to surf off the top of your RPod.
