Dirt Sifter
Topic: LED TAIL LIGHT ISSUE Posted: 24 Oct 2020 at 2:31pm |
Aw, thank you.
Greg n Deb 2020 195 HRE
Posted: 24 Oct 2020 at 12:59pm |
We can't know for sure but the issue was likely not the switch itself but the LED driver circuit. LEDs need that to control brightness. They do that by switching a transistor in series with the LEDs that regulates how much current flows through the LEDs. If the transistor fails shorted then the LEDs can still be connected and glow. Here's an example driver circuit:
Dirt Sifter
Posted: 24 Oct 2020 at 12:43pm |
So I'm old and now confused. If the light is being lit by current passing thru the switch, how does changing the light make the current stop coming thru?
Dengle
Posted: 24 Oct 2020 at 7:35am |
offgrid & mcarter: Purchased from etrailer and installed Optronics LED Interior Dome Light, RVILL33. Light works properly. Issue resolved with little effort. Price $9.96 w/tax & shipping = $16.11. Wish all fixes so simple. Thank you both. Dengle
2020 Jeep Grand Cherokee,V6
w/tow package
Posted: 10 Oct 2020 at 4:27pm |
Not young either. I have an electronics background. I could troubleshoot the light, order a replacement part, repair and go forward. Is it worth my time, NOPE. +1 to Offgrid.
Dengle
Posted: 10 Oct 2020 at 1:52pm |
mcarter & offgrid: Absolutely would never have known that, regarding LEDs havingT internal power supplies. Makes sense. The world certainly has come along way considering my advanced age. I can't keep up with new technology. I will replace light and advise of hopeful success. Thanks all.
w/tow package
Posted: 10 Oct 2020 at 1:37pm |
LED lights have power supplies in them to regulate the current the LED itself is getting so the lights have consistent brightness as the battery voltage and ambient temperature changes. The power supplies use transistors in series with the LED's to do that. Probably you have a failed transistor in the power supply which is allowing a little current to leak through even when switched off.
Just replace the light as mcarter suggests. They are cheap enough that its not worth fooling with the power supply circuit unless you just want to do it out curiousity.
Posted: 10 Oct 2020 at 1:25pm |
I checked etrailer.com, they have them, same configuration, mine mounted in existing holes. Optronics LED RV Ceiling Light - White. Model # RVILL34. they are 17 bucks plus shipping.
Posted: 10 Oct 2020 at 1:09pm |
etrailer.com has them I believe, pretty common light fixture.
Dengle
Posted: 10 Oct 2020 at 12:46pm |
Offgrid & Mcarter: When I say I disabled the switch, I cut the switch wire at the light fixture. Thus, I would think there should be no juice to the light. Nothing else done. 12V power remains "on" to everything in camper and everything works normal. I did not disconnect other wires to the light fixture, figuring the switch might be faulty. Still, current must be getting through, but how? I intend on purchasing a new light fixture, believed to be the Optronics RVILL33 and install. The switch is wrecked at the solder joint and is not easily repairable. I'm kind of dumbfounded. Thanks.
w/tow package
