Solar Questions |
Post Reply | Page <1234> |
Pod People
Topic: Solar Questions Posted: 12 Dec 2020 at 10:41am |
there has been no mention of the solar charge controller in this discussion. Just to make sure I understand correctly, the solar panel feeds the solar charge controller and then on to the battery. I have a fuse between the solar charger controller and the battery. Is that correct? thank you Vann
Dirt Sifter
Senior Member Joined: 30 Dec 2018 Location: Right side OR Online Status: Offline Posts: 170 |
Post Options Quote Reply Posted: 12 Dec 2020 at 10:16am |
Thank you! Got it. Much clearer now. Will check my factory set up next time I get to the hay shed.
Greg n Deb 2020 195 HRE
'07 Tundra 5.7L., '17 Tacoma 3.5L. Both with tow packages 1 Puggle, 1 Chihuahua support staff |
Post Options Quote Reply Posted: 12 Dec 2020 at 10:06am |
I was talking about the battery to positive conductor for the solar wiring, at the battery end. There is already a 40A fuse on the battery to house wiring, located at the panel. It would be better to have that fuse located at the battery as well because otherwise that conductor isn't protected, but FR in their infinite wisdom chose not to do that.
Basically the rule of thumb for any circuit protection, regardless of voltage, is that each and every piece of wire should be protected from excess current flowing into it from any potential source. So for the solar circuit you have two sources, the battery and the solar module/controller. Say you accidentally short a cable run to a portable solar kit from the battery. The current flow which is normally from the solar to the battery will reverse and flow from the battery into the short. That's why the fuse or breaker needs to be at the battery. Current will flow into the short from the solar end also, but solar modules are by nature current limited, so if you short one out the current only goes up by about 10%, no big deal. The wire is automatically protected without needing a fuse at the solar end. OTOH, shorting the battery will produce heaps of current which without a fuse or breaker will promptly melt the insulation off the cable and start a fire. Hope that makes sense.
Dirt Sifter
Post Options Quote Reply Posted: 12 Dec 2020 at 9:39am |
Offgrid, you are wanting the fuse/circuit breaker on the battery to house wiring not the solar to battery wiring, correct?
Post Options Quote Reply Posted: 12 Dec 2020 at 4:24am |
You don’t need to worry about having solar charging while driving. You should already have charging from your tow vehicle alternator for that. And overall you’re not driving that much of the time so you will be getting a lot more amp hours of solar charging while parked. Your biggest consideration is probably going to be how often you’re camping under trees. If that’s a lot of the time then don’t permanently mount your solar module on the roof. It will do essentially nothing for you in the shade. Leaving the module portable and having a long cable for it will give you more placement options. There is also no reason you can’t start with the module portable on a cable and then mount it on the roof later.
The zamp port is nothing special. It just connects to the battery. You can use it if it’s convenient or just go to the battery directly. But please do use a fuse or circuit breaker at the battery. I’ve designed solar power systems for 40 years now and not installing fuses or circuit breakers is the number one mistake I’ve seen ppl make, sometimes with disastrous results. A shorted 12Vdc circuit can start a fire just as easily as a 120Vac circuit could if you bypass a circuit breaker. Few folks would do the latter but many for some reason ignore safety when wiring 12Vdc circuits. |
hiker39
Newbie Joined: 25 Mar 2020 Online Status: Offline Posts: 11 |
Post Options Quote Reply Posted: 11 Dec 2020 at 11:15pm |
Thanks for all the replies, this is such a great resource. I had the same though about using the roof mounted option to charge while driving, I wonder if it would add anything to the trickle charge you get when the lights are hooked up?
Thanks for the tips on batteries and hooking directly to the batteries, I'm still unclear how the Zamp connector factors into this, is the Zamp connector another way for a "suitcase system" to connect to the battery or is there more to it than that? Thanks again for all the great replies!
Dirt Sifter
Post Options Quote Reply Posted: 11 Dec 2020 at 7:59pm |
Our first solar was big and cumbersome for the 100 watts from 4 panels that had to be wired together and lugged around as the sun moved or the wind blew. This rPod came with a rooftop mounted unit and the improvements are notable. At this time the convenience and function have been really nice. The new prtable systems look a lot more convenient than the old ones but our rooftop has served our needs.
yelvington
Newbie Joined: 05 Nov 2020 Location: GA Online Status: Offline Posts: 18 |
Post Options Quote Reply Posted: 11 Dec 2020 at 3:21pm |
My current plan (which could change another 100 or so times) is to buy a single aluminum-framed glass panel and a charge controller, and use it as a portable via the Zamp port. This lets me put off the question of whether to permanently mount, add more panels, etc., as I gain experience with how it all works with my typical electrical load.
Solar doesn't work without sunshine, and a lot of our nearby camping is pretty heavily forested -- but we plan next summer to head west, where sky is open and electrical drops are scarce. There are some good videos like this on YouTube: https://www.youtube.com/watch?v=m1rlrS7QwVI This also lets me get a handle on the battery situation. When my battery eventually dies, I hope to with LiFePO, which also would require spending a couple of hundred to change the charger component of the pod's electrical system. Expecting prices to drop over the next year or so. |
Post Options Quote Reply Posted: 11 Dec 2020 at 8:39am |
You might want to start with a 100 watt or so portable system. Many folks find that sufficient. You can always add an additional 100 watt rooftop system later. Just get a controller that can handle at least 15-20 amps charge current so you don’t have to upgrade that later.
You can certainly connect the controller output directly at the batteries but please install a fuse in the positive line there, Don’t just run wires, it's not safe if you get a short. To keep your voltage drops low I suggest 10 gauge wire and a 30 amp inline fuse. Any nominal 12V 100 watt or so solar module will work, you don’t need to buy an expensive kit. Get a glass module with an aluminum frame, much more reliable and long lasting that the so-called “flexible” solar modules. You can just bolt on a couple of fold up legs made from some aluminum angle to the module so you can tilt it up facing the sun, |
Post Options Quote Reply Posted: 11 Dec 2020 at 8:35am |
You can certainly connect the controller output directly at the batteries but please install a fuse in the positive line there, Don’t just run wires, it's not safe if you get a short. To keep your voltage drops low I suggest 10 gauge wire and a 30 amp inline fuse. |
