P-pod for dry camping? |
Post Reply | Page <1 89101112 16> |
lostagain
Post Options
Quote Reply
Topic: P-pod for dry camping? Posted: 07 Apr 2021 at 2:38pm |
+1 to OG and Olddawgsrule
MarkW
Groupie Joined: 25 Jan 2021 Location: Michigan Online Status: Offline Posts: 54 |
Post Options Quote Reply Posted: 08 Apr 2021 at 8:31am |
I would say all good points to make sure that your weights are within specs, but I think it's a mistake to think that if you have sufficient 'reserve capacity' under your towing limits you're good to go. To me, trailer balance and sway control seem to be the things to worry about most. Here's an argument that 'short wheelbase' trailers (which I think we all have here) are particularly prone to instability:
https://rv.org/blogs/news/short-wheelbases-and-accidents-go-hand-in-hand |
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3221 |
Post Options Quote Reply Posted: 08 Apr 2021 at 8:46am |
Good read, thanks Mark. This would agree with Offgrid's many comments and posts in the past stating to keep at least 11% or more weight on the tongue for reducing sway and for the most part eliminating the 'white knuckle' driving experience.
Post Options Quote Reply Posted: 08 Apr 2021 at 9:03am |
So does that mean you will go weigh your rig (not just the trailer and tongue) and report the results here relative to your limits? |
Pod_Geek
Senior Member Joined: 04 Dec 2019 Location: Colorado Online Status: Offline Posts: 260 |
Post Options Quote Reply Posted: 08 Apr 2021 at 9:26am |
Interesting article. I've never seen the "back-of-ball ratio" discussed before. I believe that's the ratio of hitch ball-to-trailer axle/hitch ball-to-rear bumper. 50% = marginal-to-bad whereas 75% = good-great. Not sure how that's measured on dual-axle trailers...maybe halfway between the axles? High BOB potentially equates to higher tongue weights as well, so that would also contribute to more stability.
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L |
lostagain
Post Options Quote Reply Posted: 08 Apr 2021 at 10:07am |
Thanks for the interesting article MarkW. I agree that TV capacity is only one of many elements to be considered in safely towing a trailer.
Here is another trailer weight calculator that may be of use:
GlueGuy
Post Options Quote Reply Posted: 08 Apr 2021 at 2:14pm |
Everyone has their own idea of what constitutes overloaded.
Olddawgsrule
Senior Member Joined: 20 Sep 2017 Location: New Hampshire Online Status: Offline Posts: 1014 |
Post Options Quote Reply Posted: 08 Apr 2021 at 2:55pm |
That happens to be one the calculators used for axle placement in the builder's forum.It'sused quite a bit!
lostagain
Post Options Quote Reply Posted: 08 Apr 2021 at 3:10pm |
Wow! That proves Fords are tough trucks.
But, the all time overloads are in the coffee country of Colombia where the ubiquitous Willys is the ultimate pack mule. https://www.youtube.com/watch?v=gKf2GlFnwfI In fact, when I lived in Colombia, I lost a friend who was taking is coffee down from the mountain to sell and went off a cliff from being overloaded.
Olddawgsrule
Post Options Quote Reply Posted: 08 Apr 2021 at 3:21pm |
First you say "to make sure that your weights are within specs", yet then "I think it's a mistake to think that if you have sufficient 'reserve capacity' ". Dude your going both ways here.. You're either with factory spec's or your not. The mistake is believing you can go beyond 'comfortably'. There's a reason for those 'spec's'! Take the time and hit the scales. My town on Saturdays has no issues at all. Free if they don't print a ticket. They had fun with me and what I was doing! I know what my dry weight is of trailer alone (not stated, actual) telling me how much I can load. I know what the trailer hitched is and combined weight. No guessing, no "it works for me", no BS, actual weights. It's worth the time.. |
