Running fridge on propane |
Post Reply | Page 12> |
pedwards2932
Senior Member Joined: 21 Sep 2020 Online Status: Online Posts: 338 |
Topic: Running fridge on propane Posted: 23 May 2021 at 4:17pm |
Sounds good I need to weigh the tank to see how full it is but we haven't used it much. Thanks.
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3226 |
Posted: 23 May 2021 at 3:39pm |
During summer months we have run the fridge and HW on propane for 3 weeks straight and have not run out of propane on a 20# tank. A couple years ago we were gone for a month during September in the Rockies and RMNP running fridge, HW and the furnace (a lot) as night temps were normally in the 40's. Did go through one 20# tank and switched to another BUT the first tank was not full when we started the trip either. Regardless of that, you will have P L E N T Y of propane for 3 nights, assuming your 30# tank isn't nearly empty when you start.
pedwards2932
Posted: 23 May 2021 at 3:19pm |
Just reopening this thread....I got the 12volt pump working....issue was it was switched to winterize mode. We are getting ready to go to Maine so how long will the fridge run in propane mode on a 30 lb tank? We will only be using it for three overnights where we are diconnected so I would think one 30lb would be plenty?
Posted: 10 Mar 2021 at 6:16pm |
Couple years back there was a podder near us who had this problem and didn't check to make sure it worked before going out first time in the spring. The bypass valves were correct and finally with the pump running I moved the valve on the antifreeze stub back and forth a few times . . . it caught prime and worked!
Posted: 08 Mar 2021 at 7:05pm |
In the 179 I just prop up the mattress to access the pump, not sure in your model. But the first time I took out the mattress. Once you know what you’re looking for it’s easier.
pedwards2932
Posted: 08 Mar 2021 at 6:42pm |
That may be it as it was building air pressure and I believe the original owner had winterized it before I bought it. Wish the pump was easier to access......do you have to pull the mattress to get to it? I have a prop to hold mattress up enough to switch the water heater valves but don't think I can get to the pump very well from there.
Posted: 08 Mar 2021 at 6:20pm |
I've used the antifreeze intake to prime system that SH refers to, then closed and continued to prime pump. It can take some time for pump to prime if winterized.
Posted: 08 Mar 2021 at 6:13pm |
If the pump has not been used and the RPod was winterized, check to see that the valve for the antifreeze stub is turned to the correct position to draw from the tank. When we got ours, it was set to pull from the stub, so it was only pumping air. When I figured out that the valve was wrong and changed it, it did not take long to prime and pump from the tank.
If you have it running and you are getting an air pressure build-up, that is likely what is happening.
Posted: 08 Mar 2021 at 5:41pm |
If it hasn’t been used for awhile the pump might be having difficulty self-priming. It is above the fresh water tank after all. Be sure the FWT is completely full, hook up city water for a bit, run the pump, then disconnect city water and see if it primes. If that doesn’t work then you’ll probably need to take the pump apart and clean it out as discussed.
pedwards2932
Posted: 08 Mar 2021 at 2:06pm |
Since this was my first try at boondocking I have never tried the 12 v pump as we have always had city water. I suspect you are right something gunking up the intake on the pump. It is kind of a pain to get to it.
