Just bought a 2018 179 - towing issue |
Post Reply | Page <1 456 |
Author | ||
Topic: Just bought a 2018 179 - towing issue Posted: 23 Jun 2021 at 11:11am |
+1 on SumoSprings. I installed a set on our Frontier. It makes a world of difference.
TheBum
Posted: 23 Jun 2021 at 11:34am | |
What kind of effect do those have when you're not towing? Do you notice a difference either in a bad way or a good way?
Alan
Posted: 23 Jun 2021 at 11:45am | |
I agree, the TV height in the front will go up regardless of how heavy or long a wheelbase it has. But on a shorter wheelbase the angle is greater so it's more sensitive to how much wdh bar tension you have. I was surprised when I first adjusted mine about how much tension it required. But then I went through the numbers in the towing calculator and it made sense and matched up. On 18 inch bars I have about 400 lbs on each bar. Roughly speaking that will double under a 2g bump load. So thats about 800 bs per bar. My 1000 lb wdh hitch has bars each rated at 1000 lbs so I have a 25% safety factor on them under 2g loading. 600 lb ones would be overloaded, 800 lb ones would be right at their load limit. |
Posted: 23 Jun 2021 at 12:03pm | |
