  New Posts New Posts RSS Feed: Interior water valves
Topic ClosedInterior water valves
Teddy G View Drop Down
Direct Link To This Post Topic: Interior water valves
    Posted: 26 Apr 2021 at 6:29pm
We are a bit confused with our Rpod 190.  Underneath te bed is the water system.  Which ways should the valves point for he system to be winterized.
Many thanksSmile
Teddy G
podwerkz View Drop Down
Direct Link To This Post Posted: 26 Apr 2021 at 6:41pm
Perpendicular.
Direct Link To This Post Posted: 26 Apr 2021 at 6:42pm
Is it a 2 valve or 3 valve system?  If 2 way the valves both need to be perpendicular to the lines they are on.  If it is a 3 valve system the same applies to the 2 valves with the 3rd valve (located between the upper and lower of the 2 valves) pointing parallel to the line it sits on.
Colt View Drop Down
Direct Link To This Post Posted: 27 Apr 2021 at 3:11pm
I asked and got nothing, but if Forest River would include a wiring diagram and a flow diagram in the "owner's manual", most of these concerns would be solved.
John
'16 R-Pod 180
