No hot water |
Akneas
Newbie Joined: 07 Sep 2020 Online Status: Offline Posts: 1 |
Topic: No hot water Posted: 18 May 2021 at 9:51pm |
We have a RPod 180. This is our first time out camping this season and we have no hot water. Any ideas? Suggestions?
Thanks, Annkneas3
Akneas
Posted: 19 May 2021 at 5:48am |
I assume you are getting cold water out of the hot water faucets rather than no water at all?
Are you on shore power? If so, there is a partially hidden switch behind the water heater panel on the outside of the trailer. Switch that on and also be sure the water heater breaker in the electric panel is on. Then wait a bit. If you are not on shore power then confirm propane is getting to your other appliances. Turn on the water heater switch on the wall panel. Outside you should be able to hear the igniter try light the burner and feel heat from the burner if it ignites. If not check your 12v fuses. If that doesn't work then it gets more involved. There is a troubleshooting manual here water heater manual |
Tars Tarkas
Posted: 19 May 2021 at 7:52am |
Make sure your winter bypass valves are set for summer. TT
FJ Cruiser |
lostagain
Posted: 19 May 2021 at 7:55am |
....And check to see that the water tank has water by lifting the little handle on the pressure relief valve on your tank.
campman
Senior Member Joined: 26 Mar 2021 Location: La Salle, MB Online Status: Offline Posts: 209 |
Posted: 19 May 2021 at 8:11am |
Another thing to remember is to make sure you have water in your hot water tank before turning on your electric water heater! Test first as la stated above, before turning electric water heater on to prevent damage to electrical heater element. Another thing I learned here. :-)
Andy |
Andy and Laurie
'16 F150 5.0 4X4 w/factory tow pkg '21 RP192 "If the women don't find you handsome...at least let them find you handy!" Red-Green |
Bogart80
Newbie Joined: 12 Sep 2021 Location: Texas Online Status: Offline Posts: 3 |
Posted: 13 Sep 2021 at 7:28pm |
I recently purchased a rpod 202 2022 year model.....I'm having issues with the hot water in the shower.....both sinks have water so hot it could scald your skin...but the shower only has cold water
Jeremy Bogart
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3226 |
Posted: 14 Sep 2021 at 2:13am |
Our setup, which may be similar to yours is there is a hookup at the end of the faucet that leads to your shower head. Since you get hot water at the faucet but none at shower head the only thing between that would be a diverter valve in the head itself that is not functioning properly. If that is the case replace the shower head.
Bogart80
Posted: 14 Sep 2021 at 6:17pm |
I replaced the shower head and still no change.....it's kinda frustrating because I traded in a forrest river grey wolf with functioning hot water to learn a new system and can't figure it our
Jeremy Bogart
JR
Senior Member Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 344 |
Posted: 14 Sep 2021 at 6:41pm |
I am assuming your 202 does not have a wet bath with a hand held shower head attached to the bathroom faucet. Also I am assuming that you have never had hot water to the shower head. If both of those assumptions are true then you could start looking at the hot water feed line to have some sort of blockage in it from the assembly process. I would start where the hot water feed line tees off the hot water feed line to the bathroom and check all the breaks in the line (connections) for blockage up to the faucet. Hope this helps.
Jay
179/2019 |
Bogart80
Posted: 15 Sep 2021 at 7:14pm |
It was what appeared to be saw dust in the line....I removed the shower head held my thumb over the line turned on the water and it puked out now I have hot shower water.....thanks for the help in looking at what could be wrong...
Jeremy Bogart
