  New Posts New Posts RSS Feed: Troubleshoot microwave, dometic refer and a/c
Topic ClosedTroubleshoot microwave, dometic refer and a/c
MARCHION View Drop Down
Direct Link To This Post Topic: Troubleshoot microwave, dometic refer and a/c
    Posted: 18 Jun 2021 at 10:41pm
So after supercharging my 179 with 240volts none of the above appear “alive”. The display on both the micro and refer do not light up. I def have power to each appliance. Could I be so lucky to have only destroyed the mother board display?
Any ideas where to start diagnosing how bad each of the 3 appliances are?
The microwave could be replaced I suppose but the A/c and dometic are spendy.
Thanks
Direct Link To This Post Posted: 21 Jun 2021 at 11:15am
I don't have either the A/C or microwave so cannot comment.
Concerning the RM 8501 refer:  Are you able to run it on either 120 or propane?  In other words if you press the button for propane do you hear the ignitor clicking or when the electric button is pressed do you know if it is actually cooling even though the light doesn't light on the button?  If the ignitor clicks and gas comes on that is a good thing.  Same goes for the 120 side.  After 30 minutes or so you should be able to feel warmth on the cooling stack with your bare hand.  Also after 5 minutes or so you should be able to feel the heat escape from the black chimney stack.  At least this is a starting point.
