Air conditioner leaking when on |
Post Reply | Page 12> |
Harry & Lizanne
Newbie Joined: 05 Jun 2019 Location: Florida Online Status: Offline Posts: 19 |
Topic: Air conditioner leaking when on Posted: 30 Jul 2021 at 9:05am |
Good morning, we have a 2019 Rpod 180 and sometimes the air conditioner has a drip inside the unit. We had it checked out while it was under warranty and they couldn’t find any problems. We are camping at this time and it has rained often. We have the same amount of dripping, regardless if it rained or not. We have had to place a small doggie pad to collect the drip. Could it be moisture? Appreciate any help.
Colt
Posted: 30 Jul 2021 at 10:28am |
Condensate is supposed to drain onyo the roof and flow down one corner. check to see if your drains are plugged of if the catch pan has a leak, bend or other fault.
John
'16 R-Pod 180 |
Harry & Lizanne
Posted: 30 Jul 2021 at 2:44pm |
Thank you will do.
RoverPod
Senior Member Joined: 07 Mar 2020 Location: Virginia Online Status: Offline Posts: 118 |
Posted: 30 Jul 2021 at 6:57pm |
Also, you might need to take the inside cover off and tighten the bolts that compress the gasket. They might have loosened up.
2017 F150 XLT SuperCab
2020 rPod 180 |
Harry & Lizanne
Posted: 31 Jul 2021 at 8:18pm |
Thanks will do.
mjlrpod
Posted: 02 Aug 2021 at 10:24am |
I'm not sure what model or year you have, but the a/c will drip water whenever it runs. Of course, it should NOT drip inside. Not sure what year it started, but You should have 4 small "gutters" sticking out from the roof. They direct the dripping water to drip at one of the front or rear corners of the flat section of roof. Maybe if you level your camper with the front or back tipped down just a bit, it might help you get the drip to go where you prefer it to go.
Harry & Lizanne
Posted: 03 Aug 2021 at 5:28pm |
Thanks. I have it park at home And have no problem. Tilted a little bit backward hopefully they fridge will work well. I haven’t figure out how to take the inside cover off only see two screws but did not came off.
I have to take the outside cover and see.
Harry & Lizanne
Posted: 03 Aug 2021 at 6:19pm |
Can one one tell me how to remove the inside cover, I can only see to screws which I removed but could not remove the cover.
Posted: 03 Aug 2021 at 9:02pm |
There are at least 8 if I remember correctly. Check behind flaps and look in the circular holes with a flashlight. You will find them eventually.
Harry & Lizanne
Posted: 04 Aug 2021 at 8:30am |
Thanks
