  New Posts New Posts RSS Feed: water tank and heater
JR View Drop Down
Post Options Post Options   Quote JR Quote  Post ReplyReply Direct Link To This Post Topic: water tank and heater
    Posted: 05 Oct 2021 at 7:20pm
I have a 2019 179 and the water heater is accessible through an outdoor black panel/door, firstly you should verify that the water heater is filled with water before turning any heating source either gas or electric by opening the pressure relief valve on the tank and ensure that you have a water flow.  The system has to be under pressure either by the city water connection hooked up or by running the fresh water pump and having water available for the pump in the fresh water tank.  Once you verify that there is water in the hot water tank you can then heat it via propane gas or electric (or both).  To turn on the gas heat flip the switch for the water heater on the panel inside the trailer located on the same panel as the tank level indicator lights and battery condition lights and a switch to turn the fresh water pump on and off.  If you want to use the 120v electric heating element verify that the breaker is in the on position (and not tripped) then go outside to the water heater and find the small rocker off/on switch (mine is located in the lower left hand side of the water heater) and turn that switch on.  If you still are not getting hot water by using the electrical element you may have to push the reset buttons (one for gas and one for electrical) on the water heater (on mind) below and to the left of the pressure relief valve and above and to the right of the off/on rocker switch.  There is a black rubber panel with 2 clearly marked reset push buttons, push both buttons in.  After doing all that if you still can't get the electric heating element to work follow offgrid's instructions on how to test and or replace the heating element.  Hope this helps.
Jay
179/2019
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2021 at 8:28am
Just to clarify one point.
The source of the water (city or tank) and the source of heat for the water heater (propane or 120Vac electric, or both) are totally independent. For example, if you are in a campground with electric but no water hookups you can still run the water heater on electric and save your propane. Before you run either type of heat just be sure the hot water tank is full.
Best to do that before you leave home by connecting to city water or running the pump from a full fresh water tank through a hot water tap until no air comes out, plus another minute or so to be sure there weren't any trapped air pockets. If you then keep water in the system all season you won't need to de-air it until you winterize.
