City Water Connection Leak - With Electrical |
JR
Senior Member Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 344 |
Post Options
Quote Reply
Topic: City Water Connection Leak - With Electrical Posted: 15 Nov 2021 at 12:59pm |
Are there any hoses that are disconnected under the bed by the water pump?? Still try and identify the water leak and repair that first.
Jay
179/2019 |
podder1148
Newbie Joined: 15 Nov 2021 Location: California Online Status: Offline Posts: 2 |
Post Options Quote Reply Posted: 15 Nov 2021 at 11:42am |
2011 181g. Water heater, pump, city/fresh water hoses are under the left side of the bed, along with the main fuse box.
JR
Post Options Quote Reply Posted: 15 Nov 2021 at 11:34am |
It would be helpful to know the year and model of your Rpod many things are different in the different floor plans and they differ from year to year. But water and electricity is never good together. I would get the leak repaired first because the moisture is not good for the trailer's construction. Just my opinion.
Jay
179/2019 |
podder1148
Post Options Quote Reply Posted: 15 Nov 2021 at 10:41am |
Hi-
New owner of an older used rpod. The city water connection is leaking pretty bad - plenty of info on how to fix that. What I'm more concerned about is that the leak inside the connection is in the same compartment as the main electric feed to the fuse box - lots of wiring, including the open neutral bus mounted to the floor. Any similar concerns from other podders? Any mods done to separate the two?
