  New Posts New Posts RSS Feed: City Water Connection Leak - With Electrical
podder1148 View Drop Down
Post Options Post Options   Quote podder1148 Quote  Post ReplyReply Direct Link To This Post Topic: City Water Connection Leak - With Electrical
    Posted: 15 Nov 2021 at 10:41am
Hi-
New owner of an older used rpod.  The city water connection is leaking pretty bad - plenty of info on how to fix that.  What I'm more concerned about is that the leak inside the connection is in the same compartment as the main electric feed to the fuse box - lots of wiring, including the open neutral bus mounted to the floor.  Any similar concerns from other podders?  Any mods done to separate the two?
JR View Drop Down
Post Options Post Options   Quote JR Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 11:34am
It would be helpful to know the year and model of your Rpod many things are different in the different floor plans and they differ from year to year.  But water and electricity is never good together.  I would get the leak repaired first because the moisture is not good for the trailer's construction.  Just my opinion.
Jay
179/2019
Post Options Post Options   Quote podder1148 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 11:42am
2011 181g.  Water heater, pump, city/fresh water hoses are under the left side of the bed, along with the main fuse box.
JR View Drop Down
Post Options Post Options   Quote JR Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 12:59pm
Are there any hoses that are disconnected under the bed by the water pump??  Still try and identify the water leak and repair that first.
Jay
179/2019
