Marker Light Lense |
Post Reply | Page 12> |
Colt
Topic: Marker Light Lense Posted: 09 Feb 2022 at 11:44am |
I broke one of my marker light lenses (red). I bought a replacement from a local, handy RV place that didn't quite fit right, but was so close I thought it would stay. Somewhere between home and Mayfield, KY it fell off. Where can I get the correct replacement lense?
John
'16 R-Pod 180 |
Post Options Quote Reply Posted: 09 Feb 2022 at 12:18pm |
Is the one you need on the side or the one on your fender? If you can tell me the series # on the metal bracket I will get the part # from the RV parts and accessories book.
Colt
Post Options Quote Reply Posted: 15 Feb 2022 at 1:28pm |
I found a number in the housing, 22366-122. |
John
'16 R-Pod 180 |
Post Options Quote Reply Posted: 15 Feb 2022 at 5:13pm |
The book describes this as a waterproof LED 4" x 2" marker light. The red replacement lens is # 681-DG52717VP. The amber replacement lens is # 681-DG5 2716VP. They are $ 3.49 each. This is from the 2021 RV parts and accessories catalogue. A local RV store or internet search should easily be able to get this.
chasl
Newbie Joined: 04 Mar 2021 Location: New Mexico Online Status: Offline Posts: 30 |
Post Options Quote Reply Posted: 15 Feb 2022 at 5:48pm |
Jato. You (and others) are helpful to everyone, with your knowledge, advice, and even research like this. Just a quick thanks. C
cl
Post Options Quote Reply Posted: 16 Feb 2022 at 7:39am |
Thanks Chasl, Over the years on this forum I have been on the receiving more than the giving end. Glad to be able to assist others when possible.
Colt
Post Options Quote Reply Posted: 17 Feb 2022 at 11:45am |
I found some online. Thanks! Before order, I'll go by my local RV store to see if they can get it! I didn't see the number and we had trouble matching the broken pieces.
John
'16 R-Pod 180 |
Post Options Quote Reply Posted: 17 Feb 2022 at 1:32pm |
Worst case scenerio is if they cannot match a lens and you opt not to order the above part number you can get the whole unit (base, lens, and wiring) that would match for about $ 5 - $8.
Colt
Post Options Quote Reply Posted: 25 Feb 2022 at 10:34pm |
Well, I had to buy the whole light, but the lens fits the original light pretty well, so I'll see how it holds up.
John
'16 R-Pod 180 |
Post Options Quote Reply Posted: 26 Feb 2022 at 7:36am |
If it isn't a tight fit replace the whole unit. Only 2 screws, pull it out, undo the wire nuts, replace with your new one, shouldn't take more than 5 - 10 minutes.
