Awning question? |
Post Reply | Page 12> |
_WW_
Newbie Joined: 25 Dec 2021 Location: Mt Vernon, WA Online Status: Offline Posts: 16 |
Topic: Awning question? Posted: 17 Mar 2022 at 11:22am |
We have 2016 179 and the room that attaches to the side. What I'm wondering is if we can install an awning also. Is there framing support for one? I had heard that if it didn't come with one that you cannot attach one. Is this true?
2014 RAM 1500
2016 R Pod 179 |
Post Options Quote Reply Posted: 17 Mar 2022 at 12:07pm |
You can easily attach an awning to the keder rail that runs along the top on the non-slide-out side. However, having a retractable awning similar to what comes on some new Rpods requires framing support to be built into the wall, which your Rpod will not have.
Pod People
Post Options Quote Reply Posted: 18 Mar 2022 at 9:18am |
_WW_
Post Options Quote Reply Posted: 18 Mar 2022 at 9:35am |
I like the Keder tape and tarp idea. Does that tape slide in and out easily?
2014 RAM 1500
2016 R Pod 179 |
Senior Member Joined: 06 Sep 2016 Location: Quaker Hill, CT Online Status: Online Posts: 2587 |
Post Options Quote Reply Posted: 18 Mar 2022 at 11:07am |
An alternative to using Keder tape is to use sail slides, spaced at a convenient distance. Since they usually made of a hard plastic or nylon, they move easier through the rail and tend not to get stuck like the tape can. They are available in various sizes to fit the different rail sizes. Here is an example of what they look like: https://www.velasailingsupply.com/ronstan-sail-slide-stainless-bail-48mm-x-11mm/?sku=RONPNP103&gclid=Cj0KCQjw29CRBhCUARIsAOboZbIRomkJP2-Uirsl5To515l-lTw58NjavVz3LFCkkwi--qvYhDIfn_gaAnKmEALw_wcB
Pod People
Post Options Quote Reply Posted: 19 Mar 2022 at 8:24am |
the keder tape will slide in the channel. However, sometimes the screws holding the channel in place have not be tightened properly and the heads will protrude, causing some resistance. Once you tighten the screws, it will slide easier. I have also used a dry spray lube that helps. Overall, it is still a great system and we are happy with the results. safe travels Vann
_WW_
Post Options Quote Reply Posted: 19 Mar 2022 at 10:10am |
Many thanks for the ideas guys! ...Wayne
2014 RAM 1500
2016 R Pod 179 |
EchoGale
Post Options Quote Reply Posted: 19 Mar 2022 at 3:59pm |
I'm traveling so sewing the keder strip isn't possible. I'm using heavy duty suction cups, adjustable poles and a "sail shade" all from Amazon for about &75. It's working really well. Maybe this link will show it off:
https://twitter.com/julieingersoll/status/1500942653935931394?s=20&t=6fpeHaN1-4Ho8BIxpkGHUg |
Julie
poston
podders Helping podders - pHp Joined: 28 Mar 2018 Location: Nevada Online Status: Offline Posts: 195 |
Post Options Quote Reply Posted: 19 Mar 2022 at 4:06pm |
Just putting it here for easier viewing: |
-- Jim Virginia City, Nevada 2016 R-pod 180 2015 Nissan Xterra Pro-4X |
EchoGale
Post Options Quote Reply Posted: 19 Mar 2022 at 4:09pm |
That was very kind of you, thanks. I've had no luck with the posting process within the forum.
Julie
