  New Posts New Posts RSS Feed: Rewinterizing after transport to MN
kvriezen View Drop Down
Post Options Post Options   Quote kvriezen Quote  Post ReplyReply Direct Link To This Post Topic: Rewinterizing after transport to MN
    Posted: 26 Mar 2022 at 12:36pm
Newbie here. We just purchased an rpod that was dewinterized in PA. But we are now in Minneapolis, MN where temps are below freezing over night to about 14°
Do I need to quick winterize again? Would running the furnace over night cover me until this cold spell us ends?
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 5:20pm
Has water been re-introduced to the lines? If not you are fine but if there is water in the lines open the drain to the HW tank, it takes a 1 1/16 socket to remove.  Move your valves to winterization mode.  I would re-winterize with that cold of a temp.  Cheaper to use a gallon of RV antifreeze thank fix broken or split water lines.
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 5:25pm
+1 on rewinterizing. Something will freeze up at those temps if they last more than a few hours
and the heater does nothing to help with the lines below the floor, and not much for the rest of the lines which are in the floor and not insulated. Winterizing is easy and cheap insurance.
