ZAMP SOLAR 6 watt |
Pod People
Topic: ZAMP SOLAR 6 watt Posted: 27 Apr 2022 at 1:30pm |
the meter will read a negative number(-12.3 etc) safe travels Vann
Texasvet1991
Newbie Joined: 04 Apr 2022 Location: N. MYRTLE BEACH Online Status: Offline Posts: 7 |
Post Options Quote Reply Posted: 27 Apr 2022 at 12:09pm |
How can you tell if its REVERSE POLARITY on my RP178 using the multimeter...
James Adkerson
Texasvet1991
Post Options Quote Reply Posted: 27 Apr 2022 at 12:07pm |
Thank you will do... appreciate your help..
James Adkerson
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2631 |
Post Options Quote Reply Posted: 27 Apr 2022 at 11:29am |
The Zamp connector is wired reverse polarity on some early Rpod installations. You really need to get yourself a meter to check voltages.
Please look at possible solution under your other post.
Texasvet1991
Post Options Quote Reply Posted: 27 Apr 2022 at 11:26am |
When I plug my Zamp solar 60 watt into the Prewired Zamp port on my RPOD 178 I get a code 601..
I looked on Youtube and he said the code means battery not connected... I put the solar panel out in direct sunlight for 3 hours and get the same code 601... If the battery is dead will that be the cause???? Marine Battery 2 years old..
James Adkerson
