new R-POD171 Owner |
xhbee
Newbie Joined: 22 May 2022 Online Status: Offline Posts: 1 |
Post Options
Quote Reply
Topic: new R-POD171 Owner Posted: 23 May 2022 at 12:18pm |
Hi, This is Bee. I just purchased my first camper, an Rpod RP-171.
one Question. Website Manual write setup step: 1.Verify that the main 120VAC breaker in your RV’s power center is turned OFF. 2.Connect the power cord to shore power. 3.Return to inside the camper and turn the main 120VAC breaker in your RV's power center ON. But I don't know where the 120VAC breaker is. Anyone advices? Thanks Bee
Post Options Quote Reply Posted: 23 May 2022 at 5:39pm |
Congratulations Bee on your 171 ! Hopefully you will be able to make a lot of great memories with it as you travel this bountiful land. Locate your power panel inside your 171. We have a 177 and it is located below the bench seat on the drivers side. Yours may be located elsewhere but look for a black plastic panel that covers all the breakers. Ours has 6 breakers located on one side but if yours is newer (you should find 6 small breakers and a larger one either on top or to the left of those. |
