Forest River stripes cracking. |
Rana
Newbie Joined: 02 Sep 2018 Location: Canmore Online Status: Offline Posts: 29 |
Topic: Forest River stripes cracking. Posted: 27 Jun 2022 at 5:16pm |
I noticed when I took the cover off after this winter that the horizontal stripes on the side of our RPod have spidery cracks in them. Is there a way to repair them, or should I remove the vinyl stripes altogether? Do they come off easily, or does one have to use a solvent, and if so, which one?
I understand that FR don't keep a stock of these older stripes, and the newer ones are a different color. Any suggestions would be a help. Thanks so much.
Rana
Stay well and stay healthy in these difficult times. |
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3220 |
Post Options Quote Reply Posted: 27 Jun 2022 at 5:31pm |
A friend of ours used a hair dryer with a plastic scraper and the decals came of rather easily. They then applied a little bit of "Goo Gone" to get rid of the sticky left behind. For 11+ years I have used a product called 'Protect All' on all the decals on our 177. I put it on 2x year. Spray it on, let sit for 30 seconds and then wipe off. The decals still look nearly new with just a little bit of crazing, but no cracks.
Post Options Quote Reply Posted: 28 Jun 2022 at 10:09am |
Ours has the same issue on the side that faces the sun most of the time while it's in storage. The decals, sadly, do not hold up well in UV. Jato's suggestion is great, except ours are already half gone (the south half). My personal choice will probably be to just remove them and to go unadorned.
gpokluda
Senior Member Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 275 |
Post Options Quote Reply Posted: 28 Jun 2022 at 10:51am |
We just went through this as well. Hopefully your stripe is still pliable enough that a hair dryer and Goo Gone do the trick. Our stripes and decals were hard and brittle so we had to use a heat gun on high setting, a metal scraper and Rapid Remover. We did purchase some replacement decals from RVDecals Direct. They are pricey but we want to have something on the green Pod. Plan on having a stripe made from outdoor sign vinyl as well.
Best of luck! |
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Triumph T120 |
Rana
Post Options Quote Reply Posted: 28 Jun 2022 at 11:07am |
Thanks so much for the reply, I'll try with the hairdryer and solvent and see what happens!
Rana
Rana
Post Options Quote Reply Posted: 28 Jun 2022 at 11:08am |
Yes, just the sunny side when in storage! I'll try with the hairdryer and solvent and see how it does.
Thanks so much for the reply.
Rana
Rana
Post Options Quote Reply Posted: 28 Jun 2022 at 11:10am |
Thanks, all good suggestions, I'll probably have to do both sides for conformity, as my wife says! Bit concerned about using a heat gun or torch, I am not quite that handy!
Thanks again.
Rana
poston
podders Helping podders - pHp Joined: 28 Mar 2018 Location: Nevada Online Status: Offline Posts: 195 |
Post Options Quote Reply Posted: 28 Jun 2022 at 12:34pm |
Just remember: no one can see both sides of the 'Pod at the same time! |
-- Jim Virginia City, Nevada 2016 R-pod 180 2015 Nissan Xterra Pro-4X |
Pod People
Post Options Quote Reply Posted: 28 Jun 2022 at 6:19pm |
"just remember: no one can see both sides of the 'Pod at the same time!" except your wife!! Happy wife, happy life Safe travels Vann
