I am back - Event Date: 15 Jul 2022 - 01 Aug 2022 |
tcj ![]() Senior Member ![]() ![]() Joined: 05 Jul 2018 Location: Central WA Online Status: Offline Posts: 141 |
![]() ![]() ![]() ![]() Posted: 16 Jul 2022 at 8:29am |
Welcome back gharden. Here's a thread on winterizing. http://www.rpod-owners.com/forum_posts.asp?TID=846 This is Techntrek's winterizing list in the first post on that thread. At the bottom of his post by his signature you will also find a link for his "Pod Instruction manual". Last edited 11/15/2011. Re-ordered some steps and cleaned it up.
1) Make sure the black and gray waste water tanks are empty. 2) Outside and underneath the trailer, unscrew your fresh water tank's drain and allow it to empty. 3) Turn on the water pump and open a valve to suck up any remaining water in the line between the tank and the pump. 9) Re-insert the fresh water tank plug while you are outside. 10) Turn the bypass valves on the hot water heater. The valves are inside the trailer - mine are under the bed on the road side. 17) Pour some RV antifreeze down the shower and sink drains. 18) Set the fridge's door latch so it stays open - look at the assembly on the wall of the fridge, you can slide it out some so when the door is latched it stays open enough to prevent mold from growing.
2018 R-pod 180 Hood River Edition
gharnden ![]() Newbie ![]() Joined: 08 Jun 2020 Online Status: Offline Posts: 1 |
I sold my R-Pod a couple of years ago. Just purchased a 192 model so I am glad to be back. I remember somewhere on this website where there was material that you could print of about R-Pod usage such as Winterization. Where do I find that again on the site. Thanks so much.
