2016 R-179 Slide Totally Dead |
Post Reply | Page <123 |
DHabibi
Newbie Joined: 17 Jul 2022 Location: California Online Status: Offline Posts: 12 |
Post Options
Quote Reply
Topic: 2016 R-179 Slide Totally Dead Posted: 04 Aug 2022 at 11:26am |
OK my last update on this since I finally figure it all out and got everything working. So there is a large fuse, I am assuming 30-40 amps bolted to the floor of the RV behind the fuse panel by the door. So when the positive line on my controller broke off and shorted to the ground it damaged this fuse but did not burn it. I bought a controller (used) and it turned out to have problems (my luck, returned), my own controller turned out not to be burned, the code 2 it was giving me was not making sense since it was not moving from motor to motor when I was switching connectors. Any way I put my controller in the system and powered it with an independent battery locally and everything worked. The large wire from this fuse the controller is very thick (6 gauge or so) and obviously was not damaged so this fuse is not totally burned but is not allowing enough power to go to the controller. I disconnected wire from this fuse and used a 30 amp fuse on an empty spot on the regular fuse panel and wired everything and it works great. 25A blows when the slide gets to the end or all the way in since the motors are pulling more than 25 amp when limited, 30 amp fuse is working fine. At some point I might grab another large fuse and wire things the way they were but for now using regular fuse spot in number 8 which was empty is working fine. The board should be able to handle the 27 amps or so which is getting pulled by the motors when limited. I also made a relay system using two relays which would allow me to do without the controller all together for but now things are back to normal, I am keeping the relay system and the wire system which I made for going straight to the motors for emergency use. All done, hope all of this helps. To get to the fuse for the slide you have take out the whole fuse box assembly. |
Don Habibi
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6293 |
Post Options Quote Reply Posted: 04 Aug 2022 at 2:24pm |
Hmmmm. I don't recall seeing such a fuse behind the power panel in our 2016 RP179. I'll have to look again the next time I have the power panel out.
DHabibi
Post Options Quote Reply Posted: 04 Aug 2022 at 2:36pm |
A very thick wire goes from the left side of the fuse panel to one end of this fuse and the wire that goes under the floor to the other side is going from the other side of the fuse to the controller. Silver fuse with 2 terminals screwed to the floor. I have replace with a 30 amp ATC fuse in the number 8 spot for now.
Don Habibi
