190 City Water Inlet Leak when using fresh tank |
npalumbo89
Groupie Joined: 31 Jul 2022 Online Status: Offline Posts: 66 |
Post Options
Quote Reply
Topic: 190 City Water Inlet Leak when using fresh tank Posted: 24 Sep 2022 at 8:12am |
Thank you so much! That did the trick!
Nicholas Palumbo
RoverPod
Senior Member Joined: 07 Mar 2020 Location: Virginia Online Status: Offline Posts: 118 |
Post Options Quote Reply Posted: 23 Sep 2022 at 5:28pm |
Take the screen out of the city water connection and press the button on the check valve behind the screen. There's probably debris stuck in it. Make sure the water pump is off and stand to the side so you don't get wet.
2017 F150 XLT SuperCab
2020 rPod 180 |
npalumbo89
Post Options Quote Reply Posted: 23 Sep 2022 at 10:55am |
New problem this weekend. Maybe it’s common. But I’m using my fresh water tank and not connected to city water, however, the fresh water inlet has started leaking. This hasn’t happened before, I’ve used this trailer 4 times so far and I’m new to rv camping in general. Any ideas on what this could be?
Thank you |
Nicholas Palumbo
