2021 R-pod 196 dust cap rubber seal |
Jrfich
Newbie Joined: 06 Jun 2021 Location: Maine Online Status: Offline Posts: 10 |
Post Options
Quote Reply
Topic: 2021 R-pod 196 dust cap rubber seal Posted: 22 Mar 2023 at 8:49am |
I have a r-pod 196. I went to grease the bearings and noticed there was no rubber cap on one side covering the zerk fitting. I bought a new rubber cap but cant install it as the serk fitting sticks out a little bit past
the dust cap. Is this normal? I bought this camper new |
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3237 |
Post Options Quote Reply Posted: 22 Mar 2023 at 9:37am |
What you describe is normal. You may want to compare the cap you purchased with the one that you already have on the other wheel to make certain they are identical. If so, be patient with the one you purchased, get it good and warm if it is cold outside (let it sit in some hot water for a minute to soften the rubber), it should slide in the groove quite easily.
