My 2014 172 podmods |
Post Reply | Page <1234> |
Author | ||
abikerider
Newbie Joined: 25 Dec 2022 Location: CA Online Status: Offline Posts: 25 |
Post Options
Quote Reply
Topic: My 2014 172 podmods Posted: 04 May 2023 at 11:11am |
Thanks. I did not remove the upper bunk yet, but the thought crossed my mind. Also, I treated the wood supporting the bed with the same Interbuild hard wax oil used on the countertop to make it water resistant. I also painted the plywood bed support with Rustoleum enamel for the same purpose.
abikerider
Post Options Quote Reply Posted: 04 May 2023 at 11:20am | |
Thanks. I am wondering what to do with that back window. Could you post a link to the blinds you used or the model number? I'm very interested in that. We plan on getting some solar panels for when we boondock. I'm not sure how often we will do that. The 12 volt fridge is just much less complex and therefore has less to go wrong with it. Hopefully it is reliable for us.
Post Options Quote Reply Posted: 04 May 2023 at 12:13pm | |
I like the countertop. What is the weight of it compared with the original. I would think that it weighs more, but it certainly will be more durable.
Post Options Quote Reply Posted: 04 May 2023 at 3:13pm | |
Just go to Blinds.com. Many different colors and cell thicknesses (we used 2x). Simply measure your width and length. Their reps. are very helpful if you need assistance. We went with a shade that was 2" wider than the window and 2" longer.
abikerider
Post Options Quote Reply Posted: 04 May 2023 at 4:11pm | |
I actually weighed them both and took pictures of the scale. After reviewing the pictures, the original weighed 12.4 lbs. and the butcherblock weighed 9 lbs. This did not include the flip up sections or the hardware that supports them, just the main countertop. Pressed wood is heavier than solid wood.
abikerider
Post Options Quote Reply Posted: 04 May 2023 at 4:13pm | |
Thanks for the info. I was wondering what the 2x meant.
Post Options Quote Reply Posted: 04 May 2023 at 7:04pm | |
Sorry. 2x means double cell, 3x is triple cell and so on. The double cell worked well, not too wide for the application and gave more insulating value than the single cell shade.
gpokluda
Senior Member Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 277 |
Post Options Quote Reply Posted: 04 May 2023 at 8:41pm | |
Very nice mods. Love the butcher block. What really caught my eye has nothing to do with your Rpod, but your Surly Long Haul Trucker in the background. I covered a lot of miles on mine until it was stolen. Mine was Utility Blue. Replaced it with a Kona Sutra.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Triumph T120 |
lostagain
Post Options Quote Reply Posted: 05 May 2023 at 5:33am | |
abikerider, we also raised the level of the lower bed when we took out the upper bunk. I put it at almost at the same height of the dinette seats. It comfortably accommodated both me and my wife.
abikerider
Post Options Quote Reply Posted: 05 May 2023 at 10:01am | |
Hi lostagain, That actually sounds like a good idea. I just measured and we could gain an extra 2" of width to make it 46" wide and have an extra deep storage area that could hold a propane generator if needed. I was about to cut a memory foam mattress to size, but now am reconsidering it. Hmmm, that means more work for me. It would also be nice to have the domed roof above the bed; it would feel much less claustrophobic. Thank you.
