AC COVER |
hogone ![]() Senior Member ![]() ![]() Joined: 09 Apr 2013 Location: St. Louis Online Status: Offline Posts: 1036 |
![]() ![]() ![]() ![]() Posted: 07 May 2023 at 8:55pm |
Well I just pulled in at a campground in Florida and realized my ac cover is gone!!! Ac is running fine but what are the concerns....thoughts on suggestions I should do. Thanks. Jon
Jon & Pam
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6262 |
Obviously, try to get a new one at an RV place if you can. It might be okay short term, but it likely isn't good for the internals of the AC to be exposed, especially if the electronics are not weather resistant.
On a two week trip so hopefully it lasts
Jon & Pam
Probably, but you can get a replacement sent to you if you are going to be there for a few days.
https://www.amazon.com/Dometic-Parts-3314471-003-Shroud-Penguin/dp/B007S3KCBE/ Amazon has other covers if you don't have the Penguin II AC unit.
Stephen: not doubting!!, just double checking!! this is the one i need, correct? looks right, just making sure. many thanks, and yes, it made it home!! jon
Jon & Pam
gonna throw that ac cover/shroud on today......any precautions/suggestions i should take going on the roof (except for falling off!!). appreciate any input. i way around 180 if that helps with thoughts. jon
Jon & Pam
poston ![]() podders Helping podders - pHp ![]() ![]() Joined: 28 Mar 2018 Location: Nevada Online Status: Offline Posts: 195 |
After seeing your post, I saw a white one intact on the side of the road - somewhere between Chicago and Nevada, can't remember where. Guess it's not all that uncommon.
-- Jim Virginia City, Nevada 2016 R-pod 180 2015 Nissan Xterra Pro-4X |
Sorry for the delay. I'm writing from Denali NP in Alaska. No, we did not tow our trailer up here. We are on a cruise/tour. The 180 should support your weight just fine. I had been up multiple times on our 179. Just stay on the flat part. That will support you. Stay away from the curved parts. Look for one of the factory tour videos and you will see people on the roof as they are being assembled.
