  New Posts New Posts RSS Feed: AC COVER
AC COVER
hogone View Drop Down
Post Options Post Options   Quote hogone Quote  Post ReplyReply Direct Link To This Post Topic: AC COVER
    Posted: 07 May 2023 at 8:55pm
Well I just pulled in at a campground in Florida and realized my ac cover is gone!!! Ac is running fine but what are the concerns....thoughts on suggestions I should do. Thanks. Jon
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 10:15pm
Obviously, try to get a new one at an RV place if you can. It might be okay short term, but it likely isn't good for the internals of the AC to be exposed, especially if the electronics are not weather resistant.
Post Options Post Options   Quote hogone Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2023 at 7:03am
On a two week trip so hopefully it lasts
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2023 at 7:21am
Probably, but you can get a replacement sent to you if you are going to be there for a few days.
https://www.amazon.com/Dometic-Parts-3314471-003-Shroud-Penguin/dp/B007S3KCBE/ Amazon has other covers if you don't have the Penguin II AC unit.
Post Options Post Options   Quote hogone Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2023 at 7:29am
Stephen:  not doubting!!, just double checking!!  this is the one i need, correct?  looks right, just making sure.  many thanks, and yes, it made it home!!  jon
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Post Options Post Options   Quote hogone Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2023 at 8:16am
gonna throw that ac cover/shroud on today......any precautions/suggestions i should take going on the roof (except for falling off!!).  appreciate any input.  i way around 180 if that helps with thoughts.  jon
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
poston View Drop Down
Post Options Post Options   Quote poston Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2023 at 9:09pm
After seeing your post, I saw a white one intact on the side of the road - somewhere between Chicago and Nevada, can't remember where.  Guess it's not all that uncommon.
Jim
Virginia City, Nevada
2016 R-pod 180
2015 Nissan Xterra Pro-4X
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2023 at 4:29pm
Sorry for the delay. I'm writing from Denali NP in Alaska. No, we did not tow our trailer up here. We are on a cruise/tour. The 180 should support your weight just fine. I had been up multiple times on our 179. Just stay on the flat part. That will support you. Stay away from the curved parts. Look for one of the factory tour videos and you will see people on the roof as they are being assembled.
