Spoiler Lights Not Working |
alandlearned ![]() Newbie ![]() Joined: 14 Jun 2020 Location: San Francisco Online Status: Offline Posts: 29 |
![]() ![]() ![]() ![]() Posted: 09 May 2023 at 3:53pm |
Does anyone have any idea how to fix the three spoiler lights on my 2015 178 that have stopped working? Everything runs/lights up perfectly, sort of. I did a pretty good job disassembling and sanding all of the grounding connections I could find under the front of the trailer so im confident that is not the issue, at least there. I'm not really certain where to look for the green and white running light wires for the spoiler run. I can follow them around the vehicle but are they somewhere else like inside the restroom walls?
2015 R-Pod 178
2019 Chevy Silverado 1500 RST, Crew Cab; Gas V8 5.3L, RWD |
hank*pod ![]() Groupie ![]() ![]() Joined: 06 Oct 2022 Location: PA Online Status: Offline Posts: 61 |
Running lights share a connector on the 7-pin plug with the taillights so I'd expect the rear clearance lights to branch off one of the taillights.
I haven't traced the wires on my 2017 179 to the extent that you have on your 178 but from casual inspection of other components within the trailer I've concluded that the running lights run in a bundle in the underside on IIRC the driver's side. But I haven't yet identified the routing from the taillights up to the spoiler.
I'm hoping to avoid pulling the thing off. There's supposed to be a big access hole underneath it but that likely won't reveal its secrets.
2015 R-Pod 178
