Hood river rpod 177 rear rebuild help needed |
listeur
Newbie Joined: 08 May 2023 Location: colorado Online Status: Offline Posts: 7 |
Post Options
Quote Reply
Topic: Hood river rpod 177 rear rebuild help needed Posted: 11 May 2023 at 3:31pm |
I have a hood river 177 that has water damage from the spoiler. It pretty much destroyed the entire rear section and I had to tear out the entire rear section. The bonded wood is the question. What or where can I get either the measurements for the curved pieces that run all the way down and or what is the best thing to use to replace the curved wood that the rest of the cross pieces attach to? all advice is welcomed. At this point it is heavy duty tarped and trying to dry what remains out. I did reply to the other user that did pretty much the same thing but I have hope someone responds with a good idea for fixing this mess. I'm good enough to rebuild the rest just looking for options for the curved stuff.
listeur@gmail.com
seafans
Senior Member Joined: 24 Nov 2017 Online Status: Offline Posts: 155 |
Post Options Quote Reply Posted: 13 May 2023 at 4:16pm |
You have quite a project there. There is boat plywood purchased by the sheet and cut out the angles to match the existing form. Keep the weight down as much as possible in the back or it won't tow properly. The only strength is needed something to fasten the outside sheeting to. Good luck.
1nana2many
Groupie Joined: 05 Apr 2018 Location: NE Kansas Online Status: Offline Posts: 62 |
Post Options Quote Reply Posted: 13 May 2023 at 4:56pm |
A few years ago, we had to tear apart out Coachman Captiva and rebuild it due to water damage coming in through the marker lights. We basically did our own laminating by using 1/8” sheets of plywood and doing a couple layers that we glued, clamped and screwed or Brad nailed together right on the curve. We replaced/added a couple 2 x 2s as cross braces because the original framing was stapled together scraps with air gaps between pieces, literally not supporting anything. Use stainless screws wherever you put them to prevent rusting. You will have to find creative ways to clamp across the camper to help get the curve into the new wood. Be generous with the glue! Hopefully you can reuse the outside skin. It’s a multiple person job getting it to mold to the shape you want, but you can do it! One thing about tearing apart an RV, you will KNOW when you finish that it far better built then it was when it left the factory!
2016 RP179= O.D. (Olive Drab) 2008 Coachman Captiva 1993 Jayco 1206 popup 2016 F150 Supercrew |
listeur
Post Options Quote Reply Posted: 14 May 2023 at 11:51am |
thanks for the advise. Stainless screws are a must. Marine grade wood and aluminum seems to be the way to go. I find it amazing we only really expect these to last for a decade. My canned ham Belle 1973 was still in perfect condition when we sold it. My 1979 American Clipper had a minor leak in the rear panel and due to better materials was an easy fix. I guess you get what you pay for these days.
I can rebuild it- it's all about time and effort. The crummy thing is it is a 5 hour drive away in Fruita colorado and fabricators are more geared for farming out there. I'll post the progress |
listeur@gmail.com
