12 volt circuit at fuse panel only 3 volts |
Post Reply | Page 12> |
Tars Tarkas
Post Options
Quote Reply
Topic: 12 volt circuit at fuse panel only 3 volts Posted: 09 Aug 2023 at 6:49pm |
Depends on what you mean by "appears to be fine". If you just eye-balled it without taking the cable off, wire-brushing it, the frame, and the bolt holding everything together, it simply doesn't count. The other ground should have helped, but what size wire was it and are you sure it was connected to bare metal. Hopefully the dealer will be able to figure it out. I know several of us will be very interested to hear the diagnosis. TT
FJ Cruiser |
poohbill
Groupie Joined: 22 Aug 2019 Location: Idaho Online Status: Offline Posts: 87 |
Post Options Quote Reply Posted: 09 Aug 2023 at 3:50pm |
Although the connections at the batteries and frame looked OK, I cleaned everything today and added dielectric lube. My pump settled back to being the workhorse its been until recently. Thank you PHP.
2016 179 Gastropod
2017 Ridgeline |
GCRicker
Newbie Joined: 22 May 2018 Location: New Hampshire Online Status: Offline Posts: 32 |
Post Options Quote Reply Posted: 08 Aug 2023 at 8:30pm |
The ground connection to the chassis appears to be fine, and I even connected another ground connection to the battery to under a screw on the chassis. Same results. I'm taking the RPod to the dealer next week for them to take a look. I'll post what the fix is.
Thanks all for your replies.
Tars Tarkas
Post Options Quote Reply Posted: 08 Aug 2023 at 8:18pm |
Assuming the problem is with the ground, that would almost certainly work, but there's hardly any connection that can't be cleaned up and made like new. Worst case, maybe a new cable from the battery to the frame would be called for, along with wire-brushing the frame, maybe a new bolt, and some dielectric grease. Connections need cleaning from time to time. TT
FJ Cruiser |
poohbill
Post Options Quote Reply Posted: 08 Aug 2023 at 3:21pm |
My neighbor suggested a tap into the ground wire then a connection to the frame in a second location.
2016 179 Gastropod
2017 Ridgeline |
Post Options Quote Reply Posted: 05 Aug 2023 at 10:51pm |
+2 on checking the ground connection at the frame (mentioned in my previous post, #4 above). I expect that will end up being the problem.
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3226 |
Post Options Quote Reply Posted: 05 Aug 2023 at 7:22pm |
+1 !!! I had that exact thing happen to me about 5 years ago. Battery tested out at 12.72v (100% fully charged. Fuses and everything else checked 'good.' Even cleaned the battery terminals and connections. Still had a problem with the lights barely coming on, as well as the 12v water pump was dismal at best. Did as TT wisely suggests above and checked the ground from the battery to the frame, AHA, corrosion city! Cleaned that up, put on a new end piece, as well as dielectric grease, no problems since.
Thanks for bringing that up Tars! |
Tars Tarkas
Post Options Quote Reply Posted: 05 Aug 2023 at 7:03pm |
I'm not very familiar with the converter wiring, but the best idea I've heard so far is a bad ground somewhere. I'd suggest you take apart all the connections you can find, main ones first, clean them, and reconnect firmly. A little dielectric grease on the connections wouldn't hurt. Bad connections can be really insidious. You can test positive for continuity but the connection isn't good enough to let all the volts or amps through. Ask me how I know. It's worth checking before doing anything more drastic. TT
FJ Cruiser |
Post Options Quote Reply Posted: 05 Aug 2023 at 12:36pm |
The reverse polarity fuses are there to protect the converter if you connect the battery backwards, even for a moment. If one or both are blown, then somebody reversed the positive and negative connections at the battery. If they are intact, then the battery was connected properly. The second positive wire is likely from your solar controller. I am afraid I can't do much else from here. You may need to make an appointment with your dealer to get it checked out or find someone local to you who can do some diagnostics there. We are too far away for me to come and take a look at it.
GCRicker
Post Options Quote Reply Posted: 05 Aug 2023 at 11:27am |
No luck. How does the reverse polarity circuitry work? Is it controlled from the 2nd positive wire routed along the driver side of the RPod?
