  New Posts New Posts RSS Feed: Maiden voyage for 2023 R-pod 196 w/Beastmode behin
wlfclf2000 View Drop Down
Post Options Post Options   Quote wlfclf2000 Quote  Post ReplyReply Direct Link To This Post Topic: Maiden voyage for 2023 R-pod 196 w/Beastmode behin
    Posted: 16 Sep 2023 at 12:57pm
As the title says this is the first time out with our 2023 R-pod 196 w/Beastmode behind our 2023 Honda Ridgeline HPD. I used an Anderson WDH and everything pulled flat and secure. It was windy today and could feel it in the truck but not bad, the Beastmode suspension means a taller trailer overall so more in the wind. I was able to get a CAT weight on the truck and trailer as follows:
-front axle 2860
-rear axle 2920
-trailer axle 4080
That puts everything below my maximums with a fully loaded vehicle and trailer. I carried a lot of the gear in bins in the bed but that still means my tongue weight is higher than I anticipated. I will probably need to dial up the Anderson as I set it less than in the instructions. I plan to measure the tongue weight next trip to be sure. We left most of our stuff in the trailer but did take out what turned out to be way too much food. Good to know for future (longer) outings we can load it up.
Round trip was about 110 miles including back roads, hills and highway. The truck gave me 13.6 MPG round trip, not bad considering our trailer weight is probably 4600+. Truck did very well at about 60 to 63 highway speeds.
I will try to get some pictures up soon.
I am very pleased.
2023 Honda Ridgeline 2023 R-Pod 196
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 7:44pm
Welcome to this forum and your 24/7 owners manual.  Good to hear you had a great experience with your 196 and Ridgeline combination.  Tongue weight will take a lot of guess work out of having a good towing experience.  Our 177 fully loaded for a one month trip and 36 gallons of water (tank behind axle) weighs in at 2940 lbs.  To eliminate/reduce sway you need 11% or more of the loaded r-pod weight on the tongue, so take 2940 x .11 = 323 lbs.  We carry a pair of 12v batteries and also a pair of 20# propane tanks on the tongue.  Using a Shurline tongue weight scale the tongue weighs in at 340 lbs.  For 12+ years we have only utilized a $40 Curt friction bar, tow vehicles include 2wd Ford Explorers and a couple different F-150's, the one used now is a '17 F-150.  Weather conditions encountered so far have been snow (including blizzard conditions), sleet, hail, heavy rain, even creeping on back roads at 1-3 mph when roads had water 10" deep (glad we installed the riser kit!), and cross-winds in excess of 20 mph.  No issues or problems have been encountered thus far, we are very satisfied with the simple friction bar set-up.
Hope you have many more memories to be made with your set-up and can get out some more this fall; enjoy those fantastic autumn colors!
