black tank |
Post Reply | Page 12> |
ilthyn
Groupie Joined: 21 May 2013 Location: Alberta Online Status: Offline Posts: 62 |
Post Options
Quote Reply
Topic: black tank Posted: 19 Sep 2023 at 8:12am |
How to clear a plugged black water tank. Suggestions please.
2011 Pod 171 with numerous mods.
2013 DODGE RAM 1500 |
GlueGuy
Post Options Quote Reply Posted: 19 Sep 2023 at 9:58am |
Define plugged. Is the outlet clogged?
seafans
Senior Member Joined: 24 Nov 2017 Online Status: Offline Posts: 155 |
Post Options Quote Reply Posted: 19 Sep 2023 at 1:12pm |
https://www.campingworld.com/flexible-tank-wand-14497.html Only a suggestion.
ilthyn
Post Options Quote Reply Posted: 19 Sep 2023 at 4:32pm |
Thanks. I found a Drano product that includes a 58 cm spiked plastic wand. Going to try it out tomorrow after the gel hopefully does its thing. Cheers.
ilthyn
Post Options Quote Reply Posted: 19 Sep 2023 at 4:35pm |
I believe the outlet is plugged. I have bought a Drano product that includes a spiked plastic flexible wand about 58 cms long. Will try it out tomorrow after the gel has had a go at the blockage.
lostagain
Post Options Quote Reply Posted: 19 Sep 2023 at 6:35pm |
There are a number of videos on Youtube that show how to unclog the tank drain. They use a flush adaptor like this one from Amazon: https://www.amazon.com/Valterra-F02-4100-Hydroflush-Removable-Anti-siphon/dp/B0002UHVAA/ref=sr_1_55?crid=345SF6PXKTURX&keywords=rv%2Bsewer%2Bline%2Baccessories&qid=1695166479&sprefix=rv%2Bsewer%2Bline%2Baccessories%2Caps%2C104&sr=8-55&th=1
ilthyn
Post Options Quote Reply Posted: 20 Sep 2023 at 8:15pm |
ilthyn
Post Options Quote Reply Posted: 20 Sep 2023 at 8:16pm |
Thanks. A good doze of Drano seems to have cured the problem. My lady says the TP we used was not proper RV type although I bought it at an RV dealership/
Post Options Quote Reply Posted: 20 Sep 2023 at 9:45pm |
Use a good biological agent in your tank to break down the waste and TP. I'm currently using Happy Camper. I've also used RV Digiest-it, or other biological agents. Don't use anything with Formaldehyde.
hogone
Senior Member Joined: 09 Apr 2013 Location: St. Louis Online Status: Offline Posts: 1043 |
Post Options Quote Reply Posted: 26 Sep 2023 at 9:52am |
I was just going to post a similar question only mine I believe is clogged up top. I can see t paper stuck. I always thought the tube went straight down but not I think it curves in. Also what is that little mechanism that you can see below the flap. Seems everything is stuck around that. Advice appreciated. Jon
Jon & Pam
