Weird water problem need help |
LongRanger
Newbie Joined: 13 Jun 2019 Location: California Online Status: Offline Posts: 39 |
Post Options
Quote Reply
Topic: Weird water problem need help Posted: 11 Jul 2024 at 12:17pm |
So far so good. It went all night here at the campground without flowing into the fresh water tank. I bet that was it. Thanks again!
LongRanger
Post Options Quote Reply Posted: 10 Jul 2024 at 8:31pm |
Thanks. Running through your solution for issue #2 now. So far so good. The toilet issue will need to wait till I get home.
JR
Senior Member Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 366 |
Post Options Quote Reply Posted: 10 Jul 2024 at 12:12pm |
The second problem you are having is that there is a check valve on the water pump and if that gets hung up it will allow water to enter the fresh water tank while you are connected to city water. The easiest way to get the check valve working again is to 1) shut off the water from the city water, 2) pull water via your water pump out of the fresh water tank (pump 1 to 4 gallons per session). Then go back on city water. Repeat several times. The check valve should start working. As to the water going to the toilet, there may be an obstruction in the feed line to your toilet. You can disconnect the water feed line at the toilet and allow the water line to flush itself out for a short period. The water running out of the water line should just go down the shower drain to the gray water tank. Hope this helps.
Jay
179/2019 |
LongRanger
Post Options Quote Reply Posted: 10 Jul 2024 at 8:53am |
We’re out camping. We have full hookups. After setting up I noticed that when flushing the toilet we only have a slight trickle of water. All faucets in the bathroom and kitchen are working just fine.
This morning we woke up to find water leaking out of the fresh water tank fill neck. But I’m connected to city water. Somehow my fresh water tank filled up and was over full. Is this related to the toilet? I’m wondering if there is a blockage somewhere and it’s backing up into the fresh water tank. Last time we went out everything was fine. Am I missing something obvious here? 2018 RP190 |
