  New Posts New Posts RSS Feed: De-winterizing checklist
Topic ClosedDe-winterizing checklist
 Post Reply Post Reply Page  <1 78910>
mountain mist View Drop Down
Direct Link To This Post Topic: De-winterizing checklist
    Posted: 09 May 2011 at 8:48am
Grass?? What is grass? Just kidding. I live up agains't the Park and have so much shade there is only moss. But that is to be thought of also. I was just thinking of the not harming the ground, gravel in my case.
'11 Forest River r.pod 171
'10 Ford Edge
ESCAPE POD
Trudi and Austin mini-schnauzers
change here, Trudi has gone, Austin now has a small black schnauzer buddy, Bentley
Direct Link To This Post Posted: 09 May 2011 at 8:43am
Thank you. Having heard the PINK anti-freeze that should be used was not toxic, but never hurts to check and check again
'10 Ford Edge
ESCAPE POD
drdrew View Drop Down
Direct Link To This Post Posted: 08 May 2011 at 10:32pm
Thanks for that clarification! I had automotive antifreeze in my brain.
172T
Brin View Drop Down
Direct Link To This Post Posted: 08 May 2011 at 10:12pm
According to my sources, if the antifreeze is propylene glycol (not the ethylene glycol that is used in automotives), it is much less likely to be attractive and toxic to animals.   I would not test this theory by feeding it to anyone but it should be less toxic.    Personally, I would not let the animals drink the water that I would drain out but once the area is dry, it should be acceptable to allow access to it.
Terri and Craig and Panzer
2009 - 175 RPod
2000 Ford F250 XLT Extended Cab Diesel
Direct Link To This Post Posted: 08 May 2011 at 9:12pm
But dogs like the taste of it and itll kill them.
172T
Direct Link To This Post Posted: 08 May 2011 at 8:54pm
Shouldn't hurt your grass, if that is what you are asking.
Direct Link To This Post Posted: 08 May 2011 at 3:34pm
I have another question on dumping the anti-freeze. RV, of course.
Can it be dumped on the ground at my house? I ask, because I have heard it is non-toxic. But I can not find a way to ask Goggle and get the answer I am seeking.
Thanks
'10 Ford Edge
ESCAPE POD
Direct Link To This Post Posted: 02 May 2011 at 9:51pm
Should be ok, it is a food-grade chemical which won't hurt wildlife if they drink it.
Direct Link To This Post Posted: 02 May 2011 at 3:52pm
Will the de-winterizing anti-freeze hurt to be dumped in the gravel of my driveway?
My husband is looking for the step by step method to get the Pod ready for use once again.
We have stored the battery and propane tank , that much we can do.
'10 Ford Edge
ESCAPE POD
Direct Link To This Post Posted: 30 Mar 2011 at 5:19pm
Originally posted by mountain mist
I had been wondering just how to de-winterize, this being my first time.
First, have I heard correctly that the anti-freeze is ok to put in a dump station?
Yes, it's OK.
Now, when you have flushed the lines, which holding tank does this go into?
The toilet will go into the black tank, all else will go into the grey water tank.
Asking since adding the chemicals to the black tank will have you just dumping them when you go to the dump station.
Personally, I think you would probably be OK without them - if only camping a day or two.  But, the chemical would help control odor and break down the waste.  I'd splurge and add chemical.
By the way, welcome back! Smile
