Sewer hose |
Post Reply | Page 123 4> |
Suds' 179
Newbie Joined: 11 Feb 2017 Location: Illinois Online Status: Offline Posts: 13 |
Topic: Sewer hose Posted: 04 May 2017 at 7:58am |
RhinoFLEX hose fit in stock storage tube (minus the gray rubber universal attachment); encountered an unavoidable road hazard which damaged the seven-pin cord, both front stabilizers, and destroyed the the sewer-hose container - fortunately, not TV or personal injuries. Managed to return to site a few hours later, and the Rhinohose was the only survivor. I like the recommended mods for replacement.
Barb & Steve
2017 R-Pod 179 2017 Toyota Hilander |
Craneman
Senior Member Joined: 12 May 2013 Location: Tokeland,wa Online Status: Offline Posts: 387 |
Posted: 03 May 2017 at 9:41pm |
jlferris
Newbie Joined: 26 Apr 2017 Online Status: Offline Posts: 13 |
Posted: 03 May 2017 at 8:28pm |
I see your post about using a 6 x 6 plastic fencepost for the sewer hose holder is pretty old now. But I'm trying to come up with the same sort of thing on my 151. Has ground clearance ever been a problem with it mounted underneath in back?
drdrew
Groupie Joined: 14 Jan 2011 Location: missouri Online Status: Offline Posts: 88 |
Posted: 13 Mar 2011 at 9:41pm |
Thanks all! I feel enlightened.
172T
Outbound
Posted: 13 Mar 2011 at 8:57pm |
I have this one from Walmart. The elbow does fit in the stock sewer holder with my 10' hose. I keep the cone in a ziplock bag in my rpod's passthru storage (and have never used). Whatever you do, you don't want to insert/remove the elbow every time you use the dumpstation. Its a tight fit and I usually end up sitting on the ground using both hands and both feet to attach the elbow to the sewer hose.
psaman
Senior Member Joined: 26 Jun 2010 Location: Corpus Christi Online Status: Offline Posts: 231 |
Posted: 13 Mar 2011 at 8:46pm |
No, I hose it off, then store it in a cardboard box in the Pods pass-thru storage. |
2011 R-177 "Sponge-Pod"
2011 F-150 XLT "Texas Edition" |
Posted: 13 Mar 2011 at 8:40pm |
I have one that is similar, the elbow separates from the the threaded part. The treaded part gets screwed into the sewer outlet, then the elbow gets pressed in place. Love it.
drdrew
Posted: 13 Mar 2011 at 8:04pm |
Im going to guess that doo dad will not fit in the pod's standard hose holder?
172T
psaman
Posted: 13 Mar 2011 at 6:25pm |
I wholeheartedly agree with HuronSailor. This is what I use. To me, it or something like it, is a must have. |
HuronSailor
Posted: 13 Mar 2011 at 5:23pm |
The right angle fitting is nice because it gives you something to step on while you're dumping the dootah. The cone thing isn't needed to dump the tank, but if you're going to be somewhere for a while and want to semi-permanently connect the sewer hose it would come in handy.
