creating an instruction & maintenance manual |
Post Reply | Page <1 2122232425> |
Olddawgsrule
Topic: creating an instruction & maintenance manual Posted: 26 Nov 2017 at 9:45am |
Assumptions on my part. 113/108L 113 load rate cold? 108 load rate hot? And L is my speed rate (the 75mph) Now, researching a few places it seems 'D' range tires are either 6 or 8 ply. Even though the tires say 2 nylon & 2 steel plys. By the PSI rating and speed rating I'm assuming these are actually 8 ply tires.. Ya, we can use a good explanation portion in the Tire Section.. |
Post Options Quote Reply Posted: 26 Nov 2017 at 10:42am |
The "D" is the generic load rating, and the ply is what it is rated at, not necessarily the actual number of plies. So if it is 8-ply rated, it might actually have 8 plies, or it might have 4 or 6 that are stronger than the plies used when the rating was originally conceived.
The 113/108 is the load rating. The first number is when it's used in a single axle configuration, and the second number is when it's ina tandem axle configuration. The L is the speed rating, which is 75 MPH. A lot of this is explained here: Tire Ratings Explanation Google is your friend. |
Olddawgsrule
Post Options Quote Reply Posted: 26 Nov 2017 at 11:44am |
Thank very much! I am feeling better about these tires now. Read a couple horror stories about them, but on larger, heavier TT's.
Just to be clear (and to sound like a complete newbie), this rating is per tire, being double the rate for two tires for total load rating.
Post Options Quote Reply Posted: 26 Nov 2017 at 12:15pm |
gwhyland
Newbie Joined: 08 Oct 2020 Location: CT Online Status: Offline Posts: 1 |
Post Options Quote Reply Posted: 08 Nov 2020 at 7:21am |
I didn't find any info here on the High Point Microwave EC028KD7 in our 2016 Rpod 179.
I have the user manual pdf but couldn't figure out how to upload it here.
R&M Podders
Newbie Joined: 05 Feb 2021 Location: Washington Stat Online Status: Offline Posts: 11 |
Post Options Quote Reply Posted: 08 Feb 2021 at 4:05pm |
Hi All,
I really appreciate the work on getting good info together in the form of a "manual" for the R-Pod. The lack of info really became apparently to me during the dealer's PDI, when the staff conducting the walk through couldn't explain accurately exactly which power sources (battery, shore AC, LP) power each appliance in my new RP-195. For this reason, I created the matrix below. I'd appreciate feedback on this matrix to see if it is accurate (and I realize that this may not be entirely accurate for all R-Pods - e.g. Fuse/Breaker IDs might differ, rigs with smaller fridges can also operate from 12VDC battery whereas my larger fridge can't). Happy Podding,
R & M
2021 R-Pod 195 1999 Ford F250 SD |
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3226 |
Post Options Quote Reply Posted: 08 Feb 2021 at 4:29pm |
On our 177 the 110 (shore power) will run the following: lights, fantastic fan, slide out motor, water pump, furnace (runs the fan motor). Realize our 177 is now 10 years old but will be interesting to hear others comments on this. The rest looks correct to me even though I am missing a lot of 'extras' that you have as standard equipment on your 195. I do not have the following that you list: range hood fan, awning motor, tongue lift motor, television, television antenna, radio/audio center, range, microwave/convection oven or air conditioner. Wow, when I see all those extras that are missing on my 177 I am beginning to realize maybe this is why I have never had any problems (except for changing out my 10 year old refrigerator a month ago) since purchasing our R-Pod back in January 2011
Post Options Quote Reply Posted: 08 Feb 2021 at 4:40pm |
Do the televisions in the new rpods really run on 12V now? If so all I can say is it’s about time FR figured that one out,
Pete Brayton
Senior Member Joined: 29 Jul 2015 Location: Parker, CO Online Status: Offline Posts: 124 |
Post Options Quote Reply Posted: 08 Feb 2021 at 5:54pm |
My 2021 Rpod196 has a 12 volt TV but it would have been nice to have a built-in DVD player. I bought a MyDash cd/dvd/radio unit that works.
2021 Rpod 196
2013 Ford 150 V8 |
Gualalapod
Newbie Joined: 12 Oct 2020 Location: California Online Status: Offline Posts: 15 |
Post Options Quote Reply Posted: 24 Apr 2021 at 1:05pm |
Hi. We recently purchased a 2015 179 and I am wondering if you are willing to share some expertise on her. Such as, can you run the rpod heater from a battery or shore power or only propane? We have been trying to figure that out and have read many different configurations. We have just been using an electric plugged in heater but also have not camped yet.
Also, does the water pump run on 12v and shore power? I hope so... Any other items you have discovered with the 2015 will be appreciated as well. Cindy Cione Gualala, CA
Gualalapod owner
