Water heater question |
jayber
Groupie Joined: 19 Mar 2011 Location: CT Online Status: Offline Posts: 66 |
Topic: Water heater question Posted: 15 May 2011 at 7:53pm |
This is a dumb question, but how do you know you have water in the hot water heater? when you fill the fresh water tank does that also fill the heater ?
Jay
2010 Honda Odyssey RP 171 aka PodInn |
LunaPod
Newbie Joined: 28 Feb 2011 Location: Canon City, CO Online Status: Offline Posts: 37 |
Posted: 15 May 2011 at 8:02pm |
You need to turn the pump on and open the hot faucets to let the air bleed out
Mike & Barb, R Pod 173 - TV 2011Silverado
Outbound
Posted: 15 May 2011 at 10:44pm |
+1 for LunaPod
The water heater fills from the bottom with the line out on the top. When water is flowing from the hot tap, the water heater tank is full.
Posted: 15 May 2011 at 11:33pm |
If you are hooked to city water you don't have to turn on your pump, just open the hot water faucet in the sink unitl it stops sputtering. I recommend doing this at home before dry camping or you will use 6 gallons of your fresh water tank just filling the water heater.
