Hugozork
Topic: Hi everyone Posted: 25 Jun 2011 at 9:47pm |
I can acess this valve under the fridge?
FrenchyPOD 171 2011
Toyota FJ Cruiser 2008 - MIA
Podsible Dream
Posted: 25 Jun 2011 at 9:29pm |
Glad you are keeping dry in your Pod!!!
Chris and Walt
'10 RP-171 'Free Spirit'
Podsible Dream
Check the valves on the other end. The two going into the heater should be parallel to the tubing, the one in the middle should be perpendicular. That will prevent hot and cold mixing on the way to your faucets.
Chris and Walt
Hugozork
Posted: 25 Jun 2011 at 9:24pm |
The weather is very bad here in mont tremblant, lot of rain. But it give us all the time to use our rpod
FrenchyPOD 171 2011
Hugozork
Posted: 25 Jun 2011 at 9:08pm |
I have only LP turned on because there is no service in my campsite. I just check directly with the valve pressure relief and the water is very hot
FrenchyPOD 171 2011
Snowbound
Posted: 25 Jun 2011 at 8:56pm |
Hi Hugozork,
Glad to hear you got to your campsite okay. We hope you are having some good weather. It is raining a bit, and cold and windy here in Edmonton.
Our hot water too gets very hot so something is not right. It does not seem to take very long to heat up either.
T and B
Tom and Bette
in our 177 "The Gastropod"
ToddsPod
Posted: 25 Jun 2011 at 8:36pm |
Originally posted by Hugozork
Direct from my campsite, it's wonderfull , just a complain at this time the hot water Is not very hot i don't understand why. I've follow the tips from the dealer like fill up the tank prior to start the wAter heater |
Do you have both the LP and electric turned on? This helps a lot on the recovery (or startup) time. The only other thing I can think of is how long it's been on and if you have LP in your tank. I don't know if there is a temperature setting, although I'd imagine there would be. If you have the time, you might want to try it with just electric, then turn it off and run out all the hot, then try it with just the LP. That would let you know if both were working. Last I tried a shower it got hot enough to scald me .
'07 Dodge RAM 1500 ST Longbed QuadCab 4.7L V8 --- '10 Forest River R-Pod 172
Hugozork
Posted: 25 Jun 2011 at 7:59pm |
FrenchyPOD 171 2011
Podsible Dream
Posted: 24 Jun 2011 at 11:14am |
So, Hugo, tell us...how is it? or ?
Chris and Walt
BIG BEAR
Posted: 22 Jun 2011 at 11:36pm |
we have a fj cruiser, our camper is a surveyor. made by forest river it is a dual axle and a liitle heavier than the rpod. you should have no problems pulling your pod. enjoy it ,congrats
LIFE DOESNT WAIT. ENJOY IT. THE ALIEN CRAFT 2011 SURVEYOR SPORT TOYOTA FJ CRUISER
