Gray Water Tank Overflow??? |
harleyguy1
Newbie Joined: 04 Dec 2010 Location: texas Online Status: Offline Posts: 38 |
Topic: Gray Water Tank Overflow??? Posted: 12 Jul 2011 at 7:32am |
For added safety, you may also want the service tech to inspect the black water vents/connections!
Marshal
2011 R-177 Longview, Tx |
Posted: 11 Jul 2011 at 10:54pm |
If it was mine I would fill it up again to see where it was leaking.
Guests
Guest Group |
Posted: 11 Jul 2011 at 4:27pm |
My best guess agrees with the "vent theory". Since those pipes usually don't/shouldn't carry water (only air) they (the manufacturer's) probably don't put a lot of effort into making sure they are sealed really well. Let us know what you find out.
psaman
Senior Member Joined: 26 Jun 2010 Location: Corpus Christi Online Status: Offline Posts: 231 |
Posted: 11 Jul 2011 at 12:11pm |
Thanks everyone for their input. I talked to the maintenance guy at the dealer and he thinks maybe the water was coming from a drain vent, especially I guess, since the leak stopped when I opened the dump valve. Anyway, he won't know until he looks underneath the pod and they are backed up for 2 weeks. I managed to crawl underneath and looked around, but could not see anything that screamed to me "water was coming from here." Time will tell.
2011 R-177 "Sponge-Pod"
2011 F-150 XLT "Texas Edition" |
Outbound
Posted: 11 Jul 2011 at 8:52am |
Sounds like you've got a leak to me, perhaps at the vent. Time for a trip to the dealership for some warranty work.
secretbard
Posted: 11 Jul 2011 at 4:39am |
Not sure what or where your leak might be. I had a gray water overflow in the shower the first time I had her out and I can tell you that mine simply overflowed back through the drain so that by the end of my shower, I was standing in an inch of water. The first thing I would do is check under your shower and see if your drain pipe is tight. I'm not sure, but can't you take that white vent off the wall right below the bathroom door and service the under-shower area from there? It sound to me like the rising water inside the gray water tank may have reached an area inside the shower drain pipe where things might not be water tight and you might not know it until standing water rose to that level. I'm just thinking out-loud here. I might be totally off, but I'm also a new Pod owner.
2010 Rpod 172 :)
2004 Chevy Trailblazer |
TerryM
Posted: 11 Jul 2011 at 4:35am |
Normally the gray water tank will, when over filled, flow into the shower. That is because the shower drain is the lowest opening to the gray tank. I think you might have a problem. I haven't heard of any type of overflow valve on the outside of the tank. But who knows, maybe there is such a thing. Give you dealer a call (or any dealer), explain what happened and ask about it. Be sure to let us know what you find out. Good luck!
Terry |
psaman
Posted: 10 Jul 2011 at 10:18pm |
I was sitting outside SpongePod last night (enjoying some adult
beverages) while grand-daughter was showering. I noticed water pouring
out underneath the pod, from the area of the gray water tank and dump
valve.
I thought the tank had sprung a leak and I ran over and looked
underneath, but saw no leak on the bottom of the tank it seemed to be
coming from higher up. I quickly pulled the dump handle (hose was
hooked up) and once the dump started the gushing stopped. Inside, there
was some water on the floor outside the shower and underneath the bed,
but not alot. I accept responsibility for not keeping up with the tank
level; but is there some sort of overflow valve or exit for water
without pulling the dump handle or did something come loose?? This
morning everything seemed fine. I am perplexed.
