  New Posts New Posts RSS Feed: Water spill under the pod during my shower
Topic ClosedWater spill under the pod during my shower
Damour View Drop Down
Direct Link To This Post Topic: Water spill under the pod during my shower
    Posted: 15 Jul 2011 at 9:30am
No problem wth the shower curtain .. only water at the exterior (under the shower)
kymooses View Drop Down
Direct Link To This Post Posted: 15 Jul 2011 at 9:25am
I would count on it being most likely a loose joint fitting also.  After receival of our Pod on our first trip I brought along teflon tape, some plumbers putty and a tube of Goop ready to seal, tighten and properly align any an all pipe fittings we have once we started running water through them.
I found that several were loose, one was completely screwed on sideways, and a third pipe had the smallest little crack in it that I quickly threw a pipe clamp onto and of course used enough Goop to seal it until the end of time!
Goop is one of the things I always make sure I have in my toolbox.  Nearly as versatile as Duck Tape.
Let me also say though, the first times we ever showered we got water all over the floor and that was because or our own mistake, we didn't make sure the show curtain was pulled far enough up around the door and some water was hitting the door and then running down onto the floor.
So if you are sure the shower curtain is up high enough then like Podsible Dream said I'd think it was a loose joint is all.
Podsible Dream View Drop Down
Direct Link To This Post Posted: 15 Jul 2011 at 6:41am
Sounds like a loose joint between the shower drain and the grey waste tank, or perhaps crack in the piping from a stone bouncing up or something, if it is only outside and not inside the pod. With the limited ground clearance, working under the trailer is difficult, so this sounds like the pod will need a trip back to the dealer for a fix. I would also ask the dealer to check and tighten all drain joints, like under the sink, too.
Chris and Walt
'10 RP-171 'Free Spirit'
Direct Link To This Post Posted: 15 Jul 2011 at 1:22am
My husband has seen water spilling on the ground under de shower during I as taking it .
It is a problem of silicone only ?
Maybe aroud the toilet .. ?
Or do you think we have a connecting hose problem under de drain of the shower ?
Help us if you think you can
thank you
