Anyone Add an Awning ? |
Post Reply | Page <1 34567 9> |
Hodge-PODge
Senior Member Joined: 11 Apr 2011 Location: Calhoun, GA Online Status: Offline Posts: 539 |
Topic: Anyone Add an Awning ? Posted: 22 Aug 2011 at 10:11am |
It had more to do with the length of the shock-corded poles that provide the cross-center support (like an X-shape) underneath the awning - that's what gives it a kind of "dome" look. We would have had to buy additional poles and then sort of splice them together to make the shock poles center support longer. I was just trying to cover the door area and was trying to stay out of the curve of the C-channel.
2011 RP 177, the Hodge-PODge
2011 Mercedes ML350 "A man travels the world over in search of what he needs, and returns home to find it." |
this_is_nascar
Senior Member Joined: 24 Jan 2010 Location: NJ Online Status: Offline Posts: 466 |
Posted: 22 Aug 2011 at 8:28am |
Maybe I missed it, but say again, why you didn't get the awning to be wider to use more of the track? Was it that you didn't want the down-sloped look/feel of the awning?
"Ray & Connie"
Guests
Guest Group |
Posted: 22 Aug 2011 at 6:29am |
Hee hee hee! - that peculiar thing sticking out above the awning is my chimney!
I couldn't agree more....all is well that ends well. Glad you found a solution. How DID you do the chimney mod? I've never seen anything like that!
Hodge-PODge
Posted: 21 Aug 2011 at 10:33pm |
P.S. Just in case anyone else is interested in this kind of awning (see pics above), go take a peek online at http://www.vintageawnings.blogspot.com/
The lady who makes them is absolutely wonderful to work with, and she has a variety of fabrics to choose from - all posted on the website. I am very pleased with the quality of the awning and the quality of service, too. NOW we all know the correct size for the R-Pod's C-channel so what happened to me won't happen again. Don't you just love that learning curve! And all really is well that ends well.
Diane
Hodge-PODge
Posted: 21 Aug 2011 at 10:26pm |
Yes, actually I do, Furpod - thanks for asking. SUCCESS AT LAST! I took a length of 7/16 plastic tubing a little longer than the awning width, slit down the length of the tubing, and slipped it over the top of the 3/8 welt on the awning, as my awning maker had creatively suggested. It worked! It slid in the C-channel easily (I had used silicone spray previously), but yet it still fit snug enough to not pull out. And I think it looks great - I love it! Here are the pics to prove it . . . .
When I camp out, I'll be sure to tie down the vertical posts.
Posted: 15 Aug 2011 at 4:06pm |
Any post weekend updates...? |
Posted: 09 Aug 2011 at 7:01am |
I'm pulling for you!
Pun intended.
Hodge-PODge
Posted: 09 Aug 2011 at 12:45am |
Footslogger, you will LOVE the 177! Well, I love mine anyway.
A traditional pull out awning is a good idea if you are comfortable (or handy) at mounting it on the Pod. The only reason I went the route I did is that I just like the idea and the looks of a "vintage" awning.
I know what you are saying about your R-dome equivalent. My R-dome ripped and is being replaced under warranty but I don't know that I want to set it up EVERY time I camp. The "vintage" awning will give me a nice alternative. Believe it or not, it - the custom vintage awning - ALMOST looked great on the Pod - the beading was just too narrow to keep it attached! But I WILL fix it - one way or another. And then I'll post pics.
Diane
Hodge-PODge
Posted: 09 Aug 2011 at 12:33am |
Consulted the awning maker and we THINK we have a simple solution. She actually tried it out but without access to a 1/2" C-channel (her vintage awning has the 3/8" channel) she couldn't be FOR SURE that it would fit.
Here is the idea. Tomorrow I am going to Home Depot to buy a length of clear PVC tubing. It has a 7/16" outside diameter, and a 5/16" inside diameter. I am going to carefully slit the tubing open and slip it on over the 3/8" welt. It is an easy fix, inexpensive ($5.87), not messy (no glue), and should still look good, too. The only problem I forsee is that it may be TOO snug. I will let you know if it works.
Other than that, the only alternative iI like s Tech's idea to sew a new 3/8" welt alongside the existing 5/16" welt.
LESSON LEARNED: If you have a custom awning made, make sure you get the 3/8" welt for a 1/2" diameter R-Pod C-channel - (NOT 5/16" welt for a 3/8" C-Channel)!
Diane
Footslogger03
Senior Member Joined: 21 Jul 2011 Location: Laramie, WY Online Status: Offline Posts: 362 |
Posted: 08 Aug 2011 at 6:56pm |
We have the equivalent of the R-Dome on our "brand x" (T@B) now and would prefer not going that route again. Lots of work to set up (regardless of what anyone tells you) and not very cool/airy inside. Biggest issue is that they wrap around on the sides and actually block ventillation, despite the zipout panels.
We are just about to buy a modell 177 R-Pod and plan on installing a more tradional pull-out awning to block the sun while still offering maximum ventillation. MJ |
Livin' the Dream ...'Slogger
